Wiardgroup
Index last updated: 2026-04-28 23:41 UTC
Boogish
Boogish
2006-06-01 by Pierre Zeeman
Hi again,
In spite of the fact that I have more filters than I ever dreamed I would
have, I'm remain pretty stuck on buying one of the professor's.  My heart
says boogie very loudly, but my mind won't let me discount the borg just
yet.  I know the answer is get both but at present only one is possible.
I do have a few questions that may tip the balance:
- the boogie can also operate like a low pass gate, correct?  If so, I am
also correct in thinking that the number of poles determines how quickly the
gate will decay? i.e. each output will have a difference response
characteristic.
- how does resonance work in the case of the boogie?  Does it center on one
of the poles or is it across the entire circuit?  Is the resonance behaviour
different for each pole?
- I know it's possible to turn the boogie into a high pass filter by
inverting the phase relationship of some of the outs and mixing them all
together.  Is it also possible to make a band pass filter like this?
thanks very much,
rgds
Pierre
Customise your home page with RSS feeds - visit MSN SA today!
http://za.msn.com/
Re: Boogish
2006-06-02 by drmabuce
Hi Pierre,
yes
>, I am
quickly the
> gate will decay?
the number of poles affects rate of decay , but it affects other
parameters too.
This might help as a foundation:
http://www.buchla.com/historical/b200/index.html
also, it might help to look up message # 1795 on this group
on one
i'm not sure i completely understand the question but i'll give it a
try...
The boogie's resonance centers on the corner (alternately called the
'cutoff' frequency. When this corner freg moves the resonance-center
moves with it. ('poles' refer to the 'steepness' of the slope at which
  frequencies are attenuated)
In terms of general behavior, the boogie functions very much like a
'classic' analog resonant filter
 i'm at a loss on this query..(sorry)
all
> together.
and this answer is a 'best guess'
i doubt it. I think a bandpass filter would require two VC filters of
the boogie's type ...
hope that helps a little,
-doc
