Wiardgroup
Index last updated: 2026-04-28 23:41 UTC
Re: [wiardgroup] Re: Nose Ring
2004-12-17 by Andrew Scheidler
Cool :)   I would never touch something like this, cuz I'm worthless as
far as electronics, but I have a friend named Tony...
And I have a Freq Div module that would love to be involved.  And that
could run the Binary Zone...  woo hoo!
And yes, I pondered the idea of making MIDI and DIN sync from a master
clock, but it gets messy since you need 6 (equally spaced in time) MIDI
clock ticks for every square pulse.  You could calculate it, but you'd
have to do it every pulse to handle tempo changes...  the Noise Ring mod
sounds far easier.
Plus I do a lot of delays synced to tempo, and with the Mobius as a
master I can easily set the exact tempo that I want.
This list is great...
Andrew
>>> grichter@asapnet.net 12/16/04 8:02 PM >>>
There is a silkscreen layout in the manual. If you feel comfortable
working with surface mount electronics, you can put a switch in
series with D6. With D6 disconnected, you can use the "Clock
Out" jack as a "Clock In" for a 0 to 10 volt square wave. The
pattern advances on the raising edge.
The "Master Clock" program I wrote for the PSIM was intended to
provide MIDI and DIN clock out using the Noise Ring as the
master. But I never figured out how to use the timer interupts to
measure the tempo of the square wave from the Noise Ring.
--- In wiardgroup@yahoogroups.com, "Andrew Scheidler"
<xpandrew@p...> wrote:
> Yeah, I can't use the NR as a master unless I buy something
that
> produced MIDI and DIN sync from the NR Clock Out.  The mod
would *have*
> to be cheaper than that...
> Your idea of having the Ext Rate In be a *divider* would be
teets on the
> duck's back!
> Andrew
> >>> c.d.sawyer@t... 12/16/04 12:41 PM >>>
> > How difficult would it be to add Clock In capability?  So that
> internal VCO was not used at all and an external clock ran
things.
> I like to have everything (808, BZone, Fat Controller, Mobius,
PSIM,
> EGs, etc) ticking away in synchronized alien machine beats,
and it
> would be cool to use the Noise Ring as a modulator.  Maybe a
switch
> that disables the VCO and the CLOCK OUT becomes a Clock
In?
> I, too, often use one clock to sync everything in the system. One
> solution is to use the Noise Ring as the "master" clock, but
there
> obviously are situations in which it is preferable to have
another
> source generate this signal.
> IIRC in response to an earlier post on the proposed Clock In,
Grant
> had indicated he would investigate this possibility, but I don't
> think he ever posted the results... perhaps he will weigh in
now?
> My original thought was to add a switch so that the EXT RATE
CV IN
> becomes a Clock In. But your suggestion has given me an
even better
> idea: could flipping this switch convert the CLOCK OUT to a
Clock In
> *and* also allow the EXT RATE pot and EXT RATE IN to control
a clock
> divider for the pulse signal arriving at the Clock In jack?
> This would be *very* special.
> Chris
Yahoo! Groups Links
