Key assign mode issue
2015-04-16 by mpe1969@tpg.com.au
Archive for polysix.
2015-04-16 by Florian Anwander
> Hello, I have a problem with my polysix. Klm366. All the Key assign
> mode lights are stuck on and no voices working. Should I check IC1
> (74l505) ?
> My klm367 board is tested and works correctly.
> Any suggestions?
> Thank you
2015-04-16 by Tubbutec
-- http://tubbutec.de https://www.facebook.com/tubbu.tec
Hello, I have a problem with my polysix. Klm366. All the Key assign mode lights are stuck on and no voices working. Should I check IC1 (74l505) ?
Any suggestions?
Thank you
2015-04-16 by Bob Grieb
2015-04-17 by mpe1969@tpg.com.au
2015-04-17 by Tubbutec
I just checked the oscillator on the Klm366 cpu with oscilloscope. I tested both sides of the crystal. I also tested the oscillator on the klm367 board. The results looked the same for both boards (square wave looking oscillations). So I assume the oscillator is working is working.
Does 'data buses' = pins 27 to 34 of 8049 heading to keyboard. Is this correct? Thanks
Thanks I checked them out.Nothing on pins 12-15, the rest listed show something (a voltage)Thanks again
2015-04-17 by Florian Anwander
> If the crystal oscillator is running, reset in is high but no signals
> on the bus:
> I would say the CPU is dead. Maybe someone else has an idea here, but
> that is my conclusion.
> I have a lot of spare key assigners here, because I replace them with
> my ModyPoly mod. I could probably send you one if you are willing to
> pay the postage..
> -tobias
2015-04-17 by swamp.gigs@googlemail.com
2015-04-17 by Chromatest J. Pantsmaker
2015-04-17 by Bob Grieb
2015-04-30 by mpe1969@tpg.com.au
2015-04-30 by Bob Grieb
2015-05-01 by mpe1969@tpg.com.au
2015-05-01 by Bob Grieb
2015-05-01 by Dave Garfield
2015-05-02 by Bob Grieb
2015-05-02 by Dave Garfield
2015-05-03 by mpe1969@tpg.com.au
2015-05-03 by Bob Grieb
2015-05-04 by mpe1969@tpg.com.au
2015-05-04 by Bob Grieb
2015-05-04 by Ben Stuyts
> On 04 May 2015, at 13:12, mpe1969@tpg.com.au [PolySix] <PolySix@yahoogroups.com> wrote:
> Thanks, I had another look tonight. I tried to upload some oscilloscope photos but they didn't seem to save to my album.
> IC9 has a dc around -2 to 2.5v that rises to about -0.5 then drops to around -4v then returns to around -2.5v. (as a pattern) I took some photos..... Hitting keys does not seem to influence this pattern
> Ic39 (the one above ic31) does not have anything happening on pin3. IC31 has -10v on pin3.
> I was about to replace ic31 but thought I would hold off as ic9 doesn't seem to be doing what you described.
> Will try again with the photos!
> Thanks again
2015-05-05 by mpe1969@tpg.com.au
2015-05-05 by Bob Grieb
2015-05-05 by radek.tymecki@op.pl
2015-05-06 by mpe1969@tpg.com.au
2015-05-06 by Chromatest J. Pantsmaker
On Wed, May 6, 2015 at 5:23 AM, mpe1969@tpg.com.au [PolySix] <PolySix@yahoogroups.com> wrote:
Good news. I replaced ic9 (added socket) and I have some action!I am now getting sounds! The oscilloscope showed more positive voltages on ic9 leg1 and when ! hold down a cluster of notes I get an extra line (lower voltage for low note).I also replaced two switches: arpeggiator and hold. (hold was on its way out, arpeggiator didn't work)Arpeggiator is now working however not the up and down octave switches (will clean the switch tomorrow night).Other issues:Hold still does not turn off the previous note.My sixth oscillator is also about a semi-tone sharp.But it's great to hear some sounds! Filters and ADSR workingWill take some photos tomorrow night.Kudos to Bob! Thanks again.
2015-05-06 by Tubbutec
It's been a while since I've played with my P6 (shame on me), but I'm thinking that HOLD should keep playing that note until HOLD is released. I feel like that's how mine works.
2015-05-06 by Bob Grieb
2015-05-07 by mpe1969@tpg.com.au
2015-05-07 by Bob Grieb
2015-05-08 by Bob Grieb
2015-05-08 by Tubbutec
The poly six may assign the same note to the same voice if it's played again after releasing the key.Lots of synths work this way.
So it may be that the first time it assigns the note the pitch is off, then the second time it's closer,then the third time it's better, etc.
If that matches what you are seeing, then maybe this time it would be the 4051 that charges the
S&H caps for each oscillator. If that chip has too much resistance, then the cap would not fullycharge the first time the key is assigned. The cap voltage would get better after the second assignment,
and even better after the third. That's the only thing I can think of that sort of matches whatyou are describing. The key MCU and DAC should put out the same voltage every time you
press a particular key.
BTW, if you put your scope on the S&H hold cap at the output of the 4051, it will probablyload it down enough to mess things up. You may want to simply change the 4051 and see
if that fixes it. Or use the scope to debug the problem some more first.
Good luck.
From: "mpe1969@tpg.com.au [PolySix]" <PolySix@yahoogroups.com>
To: PolySix@yahoogroups.com
Sent: Thursday, May 7, 2015 9:05 AM
Subject: Re: [PolySix] Re: Key assign mode issue
I just did another check. The arpeggiator is working correctly. The reason why it was jumping up an octave on oscillator 6 was because I had the 'add lower octave' switch turned on. Which lifts the 6th oscillator an octave rather than add a lower one. With the octave switch turned off, all 6 oscillators play the same note. (phew)
Ghosting: when the poly is turned on, the ghosting is there for the first few hits. Waiting for a period of time between hits doesn't influence its behaviour (still present once the key is hit).I did a quick experiment. First hit. The note had a fast beating, hit again a slow beating (more like a slow phase), push again a fast beating, hit again, then back to normal. (approx)When using the arp the notes has the same behaviour e.g. the first few repetitions distorted/beating then normal. Once the note is sounding normal it stays like this until I hit another key. The note next to it can cause the same problemInitially I thought it was the previous note causing the beating. but I'm not so sure now as the beating/ghosting seems to change with each consecutive hit until it seems to resolve.....
I will connect the oscilloscope tomorrow night and trace the oscillator wave (see if I can find where the ghosting is introduced)
Thanks again
2015-05-08 by mpe1969@tpg.com.au
2015-05-09 by mpe1969@tpg.com.au
2015-05-09 by Bob Grieb
2015-05-14 by mpe1969@tpg.com.au
