ARP AXXE Questions !
2007-10-24 by oxygeno1313
Hi all...
i have recently got an ARP Axxe MK1 ... i was testing the synth but i
ofund something that i don't know if this is normal.
1. When i turn ON the RANDOM S&H switch and the "RELEASE" slider at
middle (more or less) position, and when i depress a note the release
goes to 0 volt. The release don't sustain the note.
2. Also if i play the notes normally and i add PORTAMENTO this doen't
affect the sound. The PORTAMENTO looks like it works like a S&H LAG
when i add S$H to the VCO or VCF. Is this is normal ?
3. The other thing that i note is when i hold a note and swith the
NOISE to ON position the tune goes up a little.
4. The synth works very well if the swith is in OFF position.
5. I already check and clean the switch and traces and everything
seems to be fine. I clean all the flux between traces and replaced
tantalum caps with a new ones. PSU restored with new caps, ic
regulator and power transitors. Sliders cleaned and lubricated.
5. Anyone know what could be the problem ?
The AXXE manual don't said anything about that. so i suspect that
there's is a problem with S&H switch.
If anyone have an idea about the decribed problem let me know.
Regards
Regards
