Re: [motm] The great 300 VCO (bracket removal)
2001-01-02 by elhardt@aol.com
david@... writes:
>>While taking these apart and re-assembling them, it became apparent that
the way the PCB bracket mounts is a PITA.  You have to remove the knobs and
loosen the the pots to get the bracket off to do any work on the board.<<
Having just finished a 3 weekend MOTM building marathon and finshing off all
my modules as of today, I noticed that same problem and thought about the
same solution.  But as a test, I was actually able to get the bracket off
without taking off the knobs and loosening the pots.  You just need to get
some needle-noise pliers and slightly bend up the those two extentions enough
so you can remove the bracket.
-Elhardt
