Re: [motm] I found it - I found it
2000-12-24 by bigd@buffalo.com
have you ever felt like your gonna explode from eating  : )
I was wondering if these can be used with the MOTM rails, as i dont think there
enough room from your photo's Larry to use them on 4 or 5 modules on the MOTM
rails, would like if it would.
Jim
J. Larry Hendry wrote:
> Some of you have been looking for metal edges that are an exact fit to slip
> over the edge of your MOTM modules for that "Moog edge" look.  Well, I have
> found something that suits that need.  See the attached photos.  These are a
> perfect slip fit over the standard MOTM panel and are just tight enough not
> to scratch the paint.  My only reservation is that the thickness of the
> brass metal (need to paint white), times two will be too thick to fit
> between the allowed gap Paul has provided.  I have come to the conclusion
> that any metal thin enough to meet that need would just be too thin to be
> worth having for this function.  So, if you select this option, you will
> need to take that into consideration.
> If you are interested in getting some of this for your own experiments:
> Micro-mark  1-800-225-1066
> or www.micromark.com
> Part # 60254   - 8 pieces to a pack for $7.60
> Size = 1/8" walls - 5/32" inside space - 0.14" metal thickness - 12" long
>    edge02.jpg       Type: JPEG Image (image/jpeg)
>                 Encoding: base64
>    edge03.jpg       Type: JPEG Image (image/jpeg)
>                 Encoding: base64
Could be do a group buy on these if indeed they will work ? Probally could save
some dough.
Jim
> Jim
> >                 Encoding: base64
> >                 Encoding: base64
2000-12-25 by J. Larry Hendry
