kenton midi to c/v converters
2000-12-21 by skin job
I'm considering getting a kenton midi to c/v converter as advertised
on synthtech, but i see some possible difficulties that i might
encounter with one.
I see that the rackmount versions have the outputs on the rear. On my
current rack, I would need some kind of breakout module to interface
it efficiently. Has anyone made one of these before?
The only reason I ask, is that I would assume that someone would have
come up with a breakout panel for one by now. If there is anyone who
had extra panels made, please let me know.
BTW: I have modded my Rolamd System 100m-180 keyboard so that all
inputs and outputs are carried on a single cable to a breakout module
for ease of integrating into a MOTM system. My method adds a control
voltage input to the keyboard via an upgrade to a 7 pin din. I am
getting ready to order panels from frontplatten in Germany, so if
anytone is even remotely interested, please let me know. I'll let you
know the specific details of the modification (one possible way of
setting it up adds a minimoog mod wheel to control pitch bend), as
well as any other questions you might ask. I'm not trying to make
money, but rather trying to save money for all and add these great
conveniences to my keyboard. This mod can work on a 181 as well, with
the way I have it set up. DON'T HESITATE TO ASK ANY QUESTIONS.
Jamers Tiller/skin_job
Re: [motm] kenton midi to c/v converters
2000-12-21 by J. Larry Hendry
as advertised on synthtech, but i see some possible
difficulties that i might encounter with one.
the rear. On my current rack, I would need some kind
of breakout module to interface it efficiently. Has anyone
James,  You did not say which Kenton.  I have a pro-2000 and I did my
breakout right on the rack ears.  You cannot get everything there, but you
can get all that I use right now.  I am attaching a low-res photo since it
is coming to the group.  If you want something hi-res from front and back I
would be happy to send it to you.  The 5 connections on the right are MIDI
IN, CVA, CVB, Gate A, and Gate B.  On the left you have the 6 aux assignable
voltages.
would have come up with a breakout panel for one by now.
If there is anyone who had extra panels made, please let me know.
# 1 Stooge Moe Bradley did make one for the Expressionist.  Ever
since then, I have thought that we should have one for the Kenton-2000
and maybe pro-4 if we have any pro-4 users.  Sometime hopefully in early
2001, Dave and are a talking about another run of panels.  We need to
do more 822 and 831s since I sold 70 of those PCBs.  We have been
taking input from others on what should be included.  We can consider
a pro-2000 breakout panel if others are interested.
# 2 Stooge, Larry Hendry
2000-12-22 by Dave Hylander
I am using the Kenton Pro-4 with my MOTM.  What I am using is a 40 point
rack mount patch bay.  I had John Kovac (Wacky Kovacy) make me 1/8' by 1/4'
patch cables to adapt the Kenton to the patch bay.  I use the rest of the
patch points as 4 point multiples and patch point inputs into my Samson
PL1602 mixer.  Works quite well and looks nice too.
Dave
>encounter with one.
