Connector survey
Connector survey
2000-12-17 by Paul Schreiber
I am designing a larger power jumper pc board with:
2ea 3-position screw terminal blocks (INcoming and OUTgoing)
some number of MTA-156 connectors
So the question is, how many MTAs? 16? 20? These are for "big ass cases". I
am
thinking maybe 18 is a good number.
You can always add another one in the case. That's the reason for the
OUTgoing terminal. You
use 3 wires and connect to the second pcb's INcoming terminal.
Re: Connector survey
2000-12-17 by doc pendergast
i'll be buildin' a modular desk with stackable cabs in a couple of
months.  it's lookin' like it'll be 20U across.   so 20 gets my vote,
though 18'd work for me as well...
peace,
doc
cases". I
> am
> Paul S.
Re: [motm] Connector survey
2000-12-17 by weather
I am
hello all,
i think there's an optimum number which is the theoretical maximum number of
modules which can be powered, less a couple to allow for things like 181
keyboards. i designed each of my cabinets with this in mind - each cabinet
can be powered by one supply (unless it's full of 800s), with a little left
over for my 181
if possible, the MTA connectors could be given a little more space though...
on a personal note paul - could you email me that fed number when you have
it
cheers
paul b
(eagerly awaiting either a voltage or bovine controlled xmas)
2000-12-17 by Dave Hylander
Paul,
I would think that using 16, 18, or 20 with the ability to serial chain the
boards, would extend the 900 past it's capacity, or would give you a single
board that does not allow the use of the available capacity.  Of course one
could buy a larger Power-One supply.
I would like to see either a 22 or 24 connector board, with wider
spacing.  Or keep the current 12 connector type, but add the screw terminal
blocks.  This would allow mounting two boards in a "big ass case" which
would reduce the length of the individual cables going to each module.
-dave-
>am
2000-12-17 by Jeffrey Pontius
> am
I suppose it depends on how big the ass of your case is.  I doing some
sketching out of modules in cases using the current line and the proposed
line of motm modules (with at least one of each module in a case, except
just 2 filters & at least 2 osc's and 2 adsr's, + 1 900) [***yes, very
subjective***], some (gu)estimates:
3 rows, 10U wide rack case: about 18 per case
4 rows, 10U wide rack case: about 25 per case
3 rows, 14U wide case: about 27 per case
These (albeit limited) (gu)estimates indicate a minimum of 18 mta's up to
maybe 28 (the latter seems a bit high).  24 would probably cover many of
the top 2 examples.
BTW I believe someone mentioned having 2 900's to power separate cases.
Would this cause problems in connecting modules from different cases?
[back for more coffee] Jeff
I haven't had any problems with 2 900's powering separate cases.
-dave-
2000-12-17 by jwbarlow@aol.com
In a message dated 12/17/2000 5:56:24 AM, weather@... writes:
>of
In a message dated 12/17/2000 8:22:01 AM, jpont@... writes:
>I
>> am
>line of motm modules, some (gu)estimates:
>to
>the top 2 examples.
I think Paul B has the right idea, base the number on the PSU current
capabilities and the average module consumption. I also agree that it might
be nice to have a little more space for the connectors themselves though I
rarely unplug them at the PSU side once they are plugged in.
And being a big ass, I can add to Jeff's points too. My plan is to build a
cabinet of three rows by 24U wide which will probably have about 40 modules
requiring power when it's finished (I will be using two of the legendary 12U
flat cabinet rails). I am using a 1.5A supply, and I think that will be more
than enough for the 40 modules (didn't Paul say that the 900's 0.8A supply
would be enough for 40 modules?). So I'd imagine 20 output connectors per
block would be enough since the larger cabinets could just use two of these.
JB
I think it's more like 26 if you use the average module requirement of 20
ma and Paul's safety factor of not using more than 65% to keep power supply
heat down.  Those of us who have installed Dave Bradley's mod for LED's for
the 800's have to tag on another 5 to 10 ma per LED I believe.  I'm using
22 as max on my setup (lots of extra LED's:)
-dave-
