> -----Original Message-----
> From: J. Larry Hendry [mailto:jlarryh@...]
> Sent: Thursday, December 07, 2000 5:21 PM
> To: motm@egroups.com
> Subject: Re: [motm] Paul, listen to reason..
> OK Paul, Since you think the ART Leveler is better (I assume
> that means
> better than your prototype) I ordered one today. They are
> $79 at Musicians
> friend. They also have something similar packaged as a tube
> pre-amp for
> $99. I'll report back to the group on my success using same
> with MOTM.
> Stooge Larry
> From: Paul Schreiber <synth1@...>
> To: <motm@egroups.com>
> Sent: Tuesday, December 05, 2000 10:47 AM
> Actually, I was not that impressed. The A.R.T. Leveller does
> a better job.
> And I can sleep
> at night.
> Paul S.
> From: "Steve Maietta" <revtor@...>
> Sent: Tuesday, December 05, 2000 10:22 AM
> Subject: [motm] Paul, listen to reason..
> > Didn't you say that you've designed and tested a tube
> > overdrive/distortion curcut?
> > You seriously wouldn't release it because of high voltage concerns?
> > I mean, it's designed already! What if we all promise not to stand
> > in water and play with the circuts? You can put some kind
> of warning
> > on it, maybe get the high voltage stuff prebuilt, leave the rest to
> > us kit builders.
> > aw gee Paul C'mon.....
> > ~Steve
> -------------------------- eGroups Sponsor
> eGroups eLerts
> It's Easy. It's Fun. Best of All, it's Free!
> http://click.egroups.com/1/9698/0/_/529958/_/976241644/
> -------_->
