AFAIK, no. At least not for signals represented as voltage levels over time (as opposed to frequencies). 4QM is just like "normal" arithmetic multiplication, with neg * neg = pos, and neg * pos = neg. 2Q multiplication forces the modulator to always be positive. Now, I don't know if it does this through full-wave rectification (same as absolute value), or half-wave (same as the function "max (x, 0)"). I suspect half-wave, since that's essentially how a linear vca works.
So for the mathematically inclined, the output voltages are:
4QM (modulator, carrier) = modulator * carrier
2QM (modulator, carrier) = max (modulator,0) * carrier
-hdan
Sent: Thursday, November 09, 2000 9:17 PM
To: motm@egroups.com
Subject: Re: [motm] Different ring mod sounds
Thanks JH for the detailed thoughts on RM (which I will be digesting for a
while)!
Now another stoopid question, is 4Q multiplication the same as cross product
multiplication and 2Q the same as dot product multiplication?
JB
In a message dated 11/9/2000 7:16:11 AM, synth1@... writes:
>The sidebands
>produced are not
>the same as a 4-quadrant multiplier, because of the "sign" of the signals
>and - values) are
>"computed" differently.
-------------------------- eGroups Sponsor -------------------------~-~>
Create your business web site your way now at Bigstep.com.
It's the fast, easy way to get online, to promote your business,
and to sell your products and services. Try Bigstep.com now.
http://click.egroups.com/1/9183/2/_/529958/_/973826249/
---------------------------------------------------------------------_->
