Moog/MOTM Cabinet
Moog/MOTM Cabinet
2000-10-22 by alt-mode
Well, Paul shipped me more modules and I didn't have a place to put them so I had to
finish off my Moog-style "upper" cabinet, even without the flat rails.  I installed
the modules with temporary wood screws for now.  It came out pretty nice, if I do
say so myself.  It is 27U wide so it holds 13x2U modules plus one 1U module.
I uploaded some pictures of the cabinet at various stages of construction into the
MOTM files area on egroups.com: http://www.egroups.com/files/motm/MoogCab/
I sent the plans out as an attachement long ago.  I'll try to dig up the file and
add it to the files area (its on another computer).
A few problems/lessons learned along the way:
- Watch out for wood warping.  A friend built the cabinet out of black birch that he
had been drying for >2 years but it still warped a bit.  It isn't bad but slightly
noticeable.
- The 3/8" bevel that I had for mounting the flat rails/modules wasn't really wide
enough.  I had my woodworker friend add an additional strip of wood on the inside to
build up the lip for mounting the rail and modules.
- I used Minwax dark walnut stain and it was *really* dark.  Again, it looks OK but
a lighter stain (such as regular walnut) would have been closer to the Moog walnut.
I lightend it a bit by rubbing the darkest spots with a rag soaked in paint thinner.
- I used some T-nuts for mounting the power distribution panels on spacers.  This
could have been done just as easy with bolts from below with washers and nuts on
top.  T-nuts didn't work with the power supply since there wasn't enough room to
insert the screws into the bottom plate of the power supply.
If you are interested in seeing a pic with the cabinet in the rest of the system,
send me a note.
Eric
Do You Yahoo!?
Yahoo! Messenger - Talk while you surf!  It's FREE.
http://im.yahoo.com/
Re: [motm] Moog/MOTM Cabinet
2000-10-22 by J. Larry Hendry
To: <motm@egroups.com>
Sent: Saturday, October 21, 2000 9:09 PM
Subject: [motm] Moog/MOTM Cabinet
I had to
installed
I do
into the
file and
that he
slightly
noticeable.
really wide
inside to
OK but
walnut.
thinner.
This
nuts on
room to
system,
send me a note.
Eric
Do You Yahoo!?
Thanks for sharing Eric.  It looks nice.  Do you have a back planned for it?
If so, made of what?  Will you have any ventilation around the PS if you
have a back?
Larry H
I had to
installed
I do
into the
file and
that he
slightly
noticeable.
really wide
inside to
OK but
walnut.
thinner.
This
nuts on
room to
system,
send me a note.
Eric
Do You Yahoo!?
Thanks.  No, I wasn't planning a back for the cabinet at the moment.  Right now it
is sitting pretty close to a wall in the middle of a "stack" with no air vents
nearby so dust accumulation should be minimal.  The depth of the box at about 10"
also provides a pretty good overhang over the modules.
If I do put a back on it, I will probably use some thin "Masonite" and put holes
around the PS. If the PS wasn't so close to the back, I would go even simpler and
tack some fabric, like chinz (sp) on the back.  I had been planning to do that for a
20" deep rack that has held my modules for about 10 months now but I noticed that
there was almost no dust on the modules in that amount of time.  If the modules had
been lower in the rack, perhaps that would have made a difference.  I find that
horizontal surfaces and stuff near the floor gets dusty in my studio.  The other
items stay fairly clean with little cleaning.
BTW, I forgot to thank you Larry, for providing the wire I used!  It was great stuff
and very easy to work with for the PS distribution.
    Eric
> have a back?
> Larry H
Do You Yahoo!?
> From: alt-mode <alt_mode@...>
Thanks for all the additional info.  It certainly is a nice looking cabinet.
I love that look and am planning a very similar cabinet (but only 24 spaces
wide and 1/2 rack space taller for "Larry's magic bus" TM.
>  I find that horizontal surfaces and stuff near the floor
> gets dusty in my studio.  The other items stay fairly
I think all my stuff came electrostatically charged from the manufacturer to
attract dust.  :)
> I used!  It was great stuff and very easy to work with for
You're welcome.  I found it to be great stuff and use it myself.  I can get
several different types of the grey stuff.  Mostly # 12, and # 14 with the
very thin and flexible insulation.  I can also get some colored stuff (8
colors) which is about # 20 (maybe 18).  I use the red, black, and white (I
wonder what for).
The good thing is it is all free.  When we run cables at work, they leave
them long for termination. So, there are a lot of 6 to 10 foot scraps of
this stuff which are useless at work, but great for synth-diy projects.  Any
one wanting some of it just ask.  The bad part is, I just pick it up whan I
am on construction sites where wiring is being done.  So, if you need it
"next week" I might not have exactly what you need on hand.
Larry H
MOTM stuff for sale
2000-10-23 by sikorsky
hello chaps
i've just seen that VEMIA (here in the UK) has three MOTM 800s up for
auction, reserve is £160 for the lot
check out www.vemia.co.uk lot number 10201
just to let my stance be known - i'm selling a pile of stuff (crap, erm
sorry, quality outboard), so i might just pick these three up (poor lonely
kittens)
however, if anyone else on this list intends bidding for them, i'll probably
just stand back and leave you to it
(private replies only..?)
the auction closes on 15th November (which is incidentally also my
birthday...)
cheers
paul b
holes
simpler and
you don't mean that glazed floral fabric that characterises the late 19th
century, and brought back into fashion in the 1980s..?
(chintz)
noooo !!!!!
still i suppose it makes a change from fake fur or cabskin
cheers
paul b
(now back with the ex-missus, but only after completely dismantling his
studio first - ho hum)
> Question--do you find the 10" depth "stable"? I was going to take
advantage
> of the shallow depth of the MOTM modules and keep depth to an absolute
> minimum (maybe 8" outside measurement), but I worry that I will plug a
patch
> cord in and push the whole thing over. Is this a silly worry? Even with
> rubber feet? That's an open question to any of you cabinet guys / Moog
> owners.
hello all (again)
my cabinet is double module depth, with power supply at rear) - it must be
around 12" deep (including patent "Oakley Lip" to protect pots in case of
dire emergency in transit). i haven't had a problem with cabinet movement
even with a three row high system - i think the secret is weight, what with
10mm MDF on an aluminium frame, the bugger has too much inertia, also a good
sturdy set of rubber feet helps
oh yes, and if you put the VCOs at the bottom and EGs at the top it keeps
the centre of gravity down :-)
cheers
paul b
2000-10-23 by alt-mode
> simpler and
> (chintz)
> noooo !!!!!
Nah, I meant the black stuff that is used on the bottom of furniture.
Bleech, the mental picture is just too take on a Monday morning!
Eric
Do You Yahoo!?
Re: [motm] MOTM stuff for sale
2000-10-23 by thomas white
Looks like you should win by default, Eh? No bids here.
Thomas White
>birthday...)
>cheers
>paul b
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
2000-10-23 by davevosh@aol.com
In a message dated 00-10-23 09:00:12 EDT, you write:
<< Nah, I meant the black stuff that is used on the bottom of furniture. >>
eric,
thats called "cambric" ( i don`t know why but as service mgr. at a furniture
store, i order it all the time for the repair guys. i usually get gray as
opposed to black. if you want to try it out, let me know and send me an
address, i`ll gladly send you some.
best,
dave v.
2000-10-23 by J. Larry Hendry
The resources of this small list never cease to amaze me.
Larry H.
at a furniture store, i order it all the time for the repair guys.
i usually get gray as opposed to black. if you want to try it
out, let me know and send me an address, i`ll gladly send
you some.
best,
dave v.
2000-10-24 by alt-mode
Wow, you learn something new every day!  Thanks Dave, for the correction,
explanation, and offer.
  Eric
BTW, I'm listening to Dweller At The Threshold "No Boundary Condition" right now.
It just arrived today.  Very good stuff by Dave Fulton & friends!  I'm anxious to
listen to more!
> eric,
> best,
> dave v.
Do You Yahoo!?
2000-10-24 by Dave Hylander
Just got mine today as well and am listening to it.  Very nice.
Dave
>right now.
>anxious to
>listen to more!
Listn' while you work!
2000-10-24 by Dave Fulton
> Dave
Condition"
> >right now.
I'm
> >anxious to
> >listen to more!
Wow! Thanks guys!
It seems like it was done years ago! (It was!) A bunch of DAT's and a
DR4d! I hope you will like the new one that now due to a "renewed"
focus on family it delayed by at least a few months!
BTW: Dave that web page was killer.
Dave F
2000-10-24 by davevosh@aol.com
In a message dated 00-10-23 19:52:41 EDT, you write:
 Larry H.
larry,
same applies to you or anyone on the list who would like to try it as "back
of the cabinet" material, if you want some, tell me how much you need and
give me an address to mail it to.
best,
dave v.
In a message dated 00-10-23 22:38:05 EDT, you write:
<< Wow, you learn something new every day!  >>
eric,
like i said, it would be no problem, just let me know and send an address if
you want to try it.
best,
dave v.
2000-10-25 by J. Larry Hendry
Thanks for the offer Dave.  I am still planning the removable closed back
approach.  However, I really do find everyone else's choices and designs
interesting.  I like stealing.... errr, I mean borrowing other people's
ideas.
Larry H
larry,
like to try it as "back of the cabinet" material, if you
want some, tell me how much you need and give me
best,
dave v.
2000-10-25 by davevosh@aol.com
In a message dated 00-10-24 21:53:23 EDT, you write:
<< I am still planning the removable closed back
 approach.  >>
larry,
okay, just wanted to offer in case it was something you could use.
best,
dave v.
