Re: [motm] More OT: PS Question
2000-09-13 by Paul Schreiber
> Since I admit I know little to nothing in the world of power supplies, can
> anyone tell me if there is any way I can turn a +12VDC power supply into a
> +-12VDC power supply? Maybe this is impossible, I don't need much current,
> just enough to run a keyboard circuit. Let me know... Thanks. -Nate
HA! One of my famous lectures coming on.
The *first day* I was in EE lab, I saw a little HP bench supply. It said "DC
output 0 - 20V".
There were 3 terminals on the front, marked +, -, and G. Whipping out
Electronotes #6
(this shows my age), I decided to build something.
Well, I carefully hooked everything up (it was a LFO, I think), power up,
and NOTHING.
I sat there for about 45 minutes doing my Stooge Larry imitation, looking at
each connection,
ohming-out each resistor (I was a little iffy on the color code). Yep, it
was all correct.
About this time the lab instructor wanders over, looked over my stuff and
sort of half laughed
and half sighed. He then pointed out that the HP was only outputting +15V. I
said "Look, it
has a minus terminal!". He calmly explaind it wasn't *really* minus, but
ground. I then
blurted out "What's this friggin' GROUND TERMINAL connected to?". Oh, that
was a *different*
ground, the chassis ground. At this point, switching majors back to physical
chemistry looked
*REAL* appealling.
The moral of the story: To get +-12V, you really need a 24V *total
potential* and you are
calling "ground" the middle point. What a "negative" voltage means is that
the ground is
*above* it by 12V.
So, the only way is to use the +12 to drive a switching inverter IC. Look at
www.maxim-ic.com
there are many there. The hard part will be getting the -12V. -5V is more
common. Also
look at Linear Tech's website. Maxim and LT parts are available from
Digikey.
As a former boss said, "Ground only exists in the basement of Bell Labs"
which he liked to
shorten to "Ground is in New Jersey!" anytime anybody in the lab said
'Ground' out loud.
In telcom, you say "Earth potential".
One day, I shall relate another "Ground" story about my first "real job"
measurement, that
caused me to blow up (literally) a $4500 scope.
((Boss's other favorite expression: "No matter how hard you try, you can't
polish a turd."))
2000-09-13 by Cary Roberts
>which he liked to
>'Ground' out loud.
We call ground ground.  But the return from the negative battery
feed is called return, not ground.  Just like neutral is not called
ground in a home electrical system even though it is connected
to ground at the main breaker panel.  The returns from equipment
in a CO are connected to ground at the main battery power
distribution frame.  What really throws the new guys is that +
goes to ground and - goes to battery.  Boy have I seen some good
arc welding.  Good thing Craftsman has a lifetime warranty on
tools.
-Cary
> arc welding.
HA! This begs the question (to all you EE-wannabes), "why is it done this
way?"
Hint: it has to do with *chemistry*, not "electronics".
>way?"
[waving arm in air]
I know.  I know.  Pick me.  Pick me.
It's because electrons are negatively charged and flow from -
to +, contrary to common misconception of + to -.  I think the
military teaches it the right way.
-Cary
2000-09-13 by steve@iwsys.com
> >way?"
>[waving arm in air]
>-Cary
I can pipe in here.  In the past 10 years the Nuclear navy has switched the
way they teach this a half dozen times.  I learned it as "electron flow"
(conventional current flow) + to - in my electrician school.  Then in
nuclear power school they said the Navy is going to start teaching "hole
flow".  The idea was - to +.  The hole comes from the space left by the
electron that just "vacated" a "hole".  WHATEVER.  The idea is there is a
difference in potential (voltage) and without it there is no current flow
whether it is + to - or - to+.  I love this conversation.  In the end it
usually leaves those with any insecurities in there knowledge sure of only
one thing - they don't know anymore.
The ironic part...  I teach this now and I teach the conventional current
flow - many nubs, as we call them, understand + to minus easier despite the
actual physics involved.
Steve...  still in Hawaii
2000-09-13 by elhardt@aol.com
steve@... writes:
(conventional current flow) + to - in my electrician school.<<
I was about to bring this up.  When I was in college 15 years ago learning
this there was conventional current flow which goes from + to -/ground.  And
there was electron flow which goes from -/ground to +, because that is the
directions that the electrons actually move from atom to atom.  But since
schematic symbols were created with conventional flow type thinking (from +
to -) that seems like the way you should think.  You don't want to start
questioning what direction your diode and transistor symbols should be
pointing if you are drawing a circuit.
-Elhardt
> [waving arm in air]
> -Cary
Bzzzzzzzzttt!
Wrong.
this
> > >way?"
Bzzzzztttt!
Wrong.
And
> -Elhardt
Bzzzzttttt!!!
Wrong.
handing out the zeros
RE: [motm] More OT: PS Question
2000-09-13 by Tony Karavidas
It has to do with electrolysis. In a huge system like this, there will be
leakage current into the earth. The leakage is through wet phone wires. In
the process of electrolysis, corrosive action is confined to the anode or
positive side.  When the wires are at negative potential compared to the
ground the metal ions go from the ground to the wire instead of the
situation where positive voltage would cause metal from the wire to leave
which causes quick corrosion.
Do I win?
Tony
> -----Original Message-----
> From: Paul Schreiber [mailto:synth1@...]
> Sent: Tuesday, September 12, 2000 9:41 PM
> To: motm@egroups.com
> Subject: Re: [motm] More OT: PS Question
> > arc welding.
> way?"
> Paul S.
We have a winner! (see, I said *chemistry*, not *physics*)
To: <motm@egroups.com>
Sent: Wednesday, September 13, 2000 12:15 PM
Subject: RE: [motm] More OT: PS Question
> Do I win?
> Tony
> > > arc welding.
this
> > way?"
> > Paul S.
2000-09-13 by The Old Crow
  Can I have any points if I say the words 'sacrificial anode'?
  (Many of these of which I had to install with power panels in factories)
Crow
2000-09-14 by jwbarlow@aol.com
I would've guessed electrolysis too -- if only do to Paul's hint. I had no
idea about the corrosion problems averted by using a positive ground, but
I've seen water mains corrode in a few years when the originals lasted about
twenty -- until the plumbers change them out and remove the ground straps
(job insurance I guess).
I'll also note that the house I currently live in (probably built in the
thirties or forties) doesn't have ground = neutral. I found this out while
recently swapping out some stereo components -- holding a tape deck in my
sweaty hands when my sweaty arm rubs against another component (OUCH!).
Apparently each side is about 60 V about the ground pin.
Sweat is a good conductor!
JB
In a message dated 9/13/2000 10:31:09 AM, tony@... writes:
>be
>In
>or
Is the keyboard you are using a CV keyboard for your MOTM for example? If so,
you may want to use the MOTM's Power One supply for accuracy's sake.
My Serge TKB outputs 0 V at the low end and 5.03 V (according to my meter) at
the high end and there is no trimmer. I've had to calibrate VCOs specifically
for use with the TKB. So little differences in the output voltage are
extremely noticeable if used for traditional pitch control.
JB
In a message dated 9/12/2000 7:53:19 PM, nate@... writes:
>can
>a
2000-09-18 by J. Larry Hendry
You don't even want to get me started on grounding and stuff like that.  I
would say the single most common cause of equipment damage is improper
grounding techniques.  I've seen about every stupid thing you can imagine.
Now as a little piece of trivia, the only way to run multiple feed DC
systems used in utility system operations is UNgrounded. Examination of  "+"
to ground and "-" to ground floating voltage measurements can tell you LOTs
about stuff that is going wrong you don't even know about yet.
Larry H
Maybe to keep from growing all that funny looking stuff on the connections?
"why is it done this way?"
