New MOTM capacitors
New MOTM capacitors
2000-07-24 by Paul Schreiber
The purple-ish-blue Panasonic caps used on every MOTM kit to bypass the
power supply rails
has been discontinued. :(
So, you will start seeing another cap, same value/rating, but probably
orange in color.
A few of the older instructions have references to the color. Don't panic:
just solder the new ones right in there!
Re: [motm] New MOTM capacitors
2000-07-24 by The Old Crow
> the power supply rails has been discontinued. :(
> orange in color.
  Bah, I'll just use some tantalums and this spool of rosincore solder I
have here... ;)
  FWIW I have some green aluminum electrolytics, now just need some yellow
and red for that prismatic effect...
Crow
