cheap mult trick
cheap mult trick
2000-06-08 by David Bivins
I have a couple Behringer Ultrapatch patch bays.
Set channels to parallel mode and connect adjacent channels from behind with
short patch cables (only one necessary for each "column"). Instant mults!
David.
RE: [motm] cheap mult trick
2000-06-09 by Tentochi
This is EXACTLY what I do.  They fit great in SKB pop-up mixer cases too.
The path bays are a bit heavy compared to others, but they are built like
tanks, easy to configure and fairly inexpensive.
I will probably get a few more soon.
--Shemp
> behind with
> David.
2000-06-09 by alt-mode
I'll also confirm this trick too!  I have a few mults in almost every patch bay.
The 6" cables needed to connect them are also pretty inexpensive.
I've had the best success with the Neutrik balanced patch bays.  Guitar Center
appears to be blowing them out at $69 now.  They have a removable front plate that
allows you to swap a set of jacks between normalled, half-normalled, etc. Very
convenient!
The final trick I have for patch bays is to lay them out in Excel and get the cell
size to match the space above each jack.  Then, you can print the labels using Avery
8.5" x 11" label stock, cut out the labels and apply them to the bays.  Also, you
can create labels for the rear of the patch bay by doing a copy, paste with
transposition, sort, and repaste with transposition.  I have found the labels on the
rear to be a really big help when trying to connect up stuff in the back of a busy
rack.
If anyone wants a spreadsheet sized for Neutrik or Tascam patch bays, I could
probably email them out.
Eric
> --Shemp
> > behind with
> > David.
Do You Yahoo!?
Yahoo! Photos -- now, 100 FREE prints!
http://photos.yahoo.com
After a few patch bays and studio reorganizations/moves, the organizational tricks
became a necessity ;)  Actually, after you've done it once, future changes are
pretty easy.  I've put a few layers of labels on some bays and I've also marked them
up as things changed rather than reprint the labels.
The old Avery labels were messy and stuck too well, requiring Goo-Gone to cleanup.
However, the newer labels remove much more cleanly now while sticking well.  You
might want to give it another try...
I use the Post-It correction tape for mixer strips all the time!  You can store
strips for old setups on the side of a rack real easy.  Well, it might require a
piece of tape on top just to keep it there....  I also use the correction tape for
scribbling things on rack mount boxes, like channel numbers or wierd routings.  But
you are right, if the tape doesn't have something to fully contact all the time, it
dries up and falls off.
Eric
--- David Bivins <dbivins@...> wrote:
> Damn--you're super organized! I've been using the 3M Post-It correction tape
> for labeling things, but it doesn't stick for very long. I've been
> considering buying a label-maker. I'd do the Avery labels, but they may
> stick *too* well, and I'm restless, always moving things around in the
> patchbay every few months.
> But thanks for the tips (especially for the backs of the 'bays)!
> David.
> > -----Original Message-----
> > From: alt-mode [mailto:alt_mode@...]
> > Sent: Friday, June 09, 2000 10:41 AM
> > To: motm@egroups.com
> > Subject: RE: [motm] cheap mult trick
> > every patch bay.
> > Guitar Center
> > front plate that
> > convenient!
> > and get the cell
> > labels using Avery
> > bays.  Also, you
> > paste with
> > the back of a busy
> > rack.
> > bays, I could
> > Eric
> > cases too.
> > built like
> > > --Shemp
> > > > behind with
> > Instant mults!
> > > > David.
> > Do You Yahoo!?
> > Get a NextCard Visa, in 30 seconds!
> > 1. Fill in the brief application
> > 2. Receive approval decision within 30 seconds
> > 3. Get rates as low as 2.9% Intro or 9.9% Fixed APR
> > http://click.egroups.com/1/5197/5/_/529958/_/960568832/
Do You Yahoo!?
2000-06-09 by David Bivins
David.
> every patch bay.
> Guitar Center
> front plate that
> convenient!
> and get the cell
> labels using Avery
> bays.  Also, you
> paste with
> the back of a busy
> rack.
> bays, I could
> Eric
> cases too.
> built like
> > --Shemp
> > > behind with
> Instant mults!
> > > David.
> Do You Yahoo!?
Re: [motm] cheap mult trick
2000-06-09 by mr sikorsky
hello all,
yep, my entire attic of doom is wired with Ultrapatch, although knowing B***er (like D***er is refered to sometimes - PLEASE don't anyone turn this into a thread) I await the day when i have to resolder the entire lot. saying that, we have a big pile of Mosses & Mitchell bantam patch at work and although these are almost the pinnacle of patch technology, they do go badly wrong after a while
however, if anyone runs Corel Presentations (on PC) AND has Ultrapatch - i have a pre-formatted labelling system i can email through (for that matter, if anyone has M&M 80 way & 96 way bantams, i have that too)
anyway, the weekend has just started, i've recovered from lugging my recently refurbished LS1s (ex BBC active monitors - TUBE DRIVEN circa 1961) into the attic, my Claret is suitably warm, and a pizza has just turned up... ...cheers paul b
2000-06-09 by Brousseau, Paul E (Paul)
I use a Neutrik balanced patch bay.  The cheap model.  And it grips jacks
like no-one's business.  I don't think I'll ever have to worry about jacks
falling out.  You do have to flip cards to change normalization, but once a
patch bay is in place, do you really need to change it that much?  (Of
course, who am I to talk?  I've had my patch bay for about a month, and its
just sitting on top of the MIDI box-- not even bolted to the rack yet!)
--PBr, who almost bought the Behringer...
> From:	David Bivins [SMTP:dbivins@...]
> Sent:	Friday, June 09, 2000 3:46 PM
> Heh. My use of Behringers (for me--your mileage may vary) is out of
> cheapness (they're cheap) and laziness (you select normalling via
> switches--no card flipping). The back jacks pretty much blow--my plugs
> pull out if you look at them cross-eyed. So the back of my rack is
> *usually* carefully arranged to avoid any stress or pressure whatsoever,
> but they still pull out. Many nights I've been happily tweaking my MOTM
> when suddenly something goes wrong--where'd the spring reverb go? Oh--it
> popped out the back of the patchbay. Sigh.
> But I can't justify anything better or soldered until my studio is stable
> (i.e. not buying everything in sight).
> David.
Heh. My use of Behringers (for me--your mileage may vary) is out of cheapness (they're cheap) and laziness (you select normalling via switches--no card flipping). The back jacks pretty much blow--my plugs pull out if you look at them cross-eyed. So the back of my rack is *usually* carefully arranged to avoid any stress or pressure whatsoever, but they still pull out. Many nights I've been happily tweaking my MOTM when suddenly something goes wrong--where'd the spring reverb go? Oh--it popped out the back of the patchbay. Sigh.
But I can't justify anything better or soldered until my studio is stable (i.e. not buying everything in sight).
David.
Sent: Friday, June 09, 2000 2:02 PM
Subject: Re: [motm] cheap mult trick
hello all,
2000-06-10 by Charles Stella
I have a Brother P-Touch for labeling. I love this thing! Cost about $80
but has many uses. You can buy the labels in all sorts of sizes and
colors. And for the ultra-cheap mult I use these Headphone type splitter
jacks but with the mono plugs. You just plug the single end into a jack
and you have two outputs instantly. You can move them around at will and
they are fairly low profile. And did I say cheap!. Charles.
> correction tape
> may
> David.
> > every patch bay.
> > Guitar Center
> > front plate that
> > convenient!
> > and get the cell
> > labels using Avery
> > bays.  Also, you
> > paste with
> > the back of a busy
> > rack.
> > bays, I could
> > Eric
> > cases too.
> > built like
> > > --Shemp
> > > > behind with
> > Instant mults!
> > > > David.
> > Do You Yahoo!?
