Re: [motm] enigiser - some old info
2000-05-31 by ivancu@aol.com
Date: Tue, 24 Feb 1998
To: pfperry@...
Cc: analogue@...
Subject: Re: Orgon enigizer ???
> >Hi to all, > >Has anyone ever heard about this synth  Orgon enigizer ??? >
>It's probably a 1997 machine, with 15-pole analog VCF, one VCO plus a > >Sub
osc. > > > someone is either very satirical or pulling your leg.... > or else
this is an amazing coincidence, with 'orgone energy', a part of= =20 >
Reich's delusional quack medicine theories....  =2E..or someone decided that
said theories were so amusing that they would make a good name on a synth :-)
It was existant enough for "The MIX" to put it on the cover of its december
-96 issue. They also had a long article inside about this amazing new
monosynth - Designed and built by Orgon systems, aka Geoff Waterstone. At
that time they/he were reachable on 0191 2902592, and the synth cost £469.
Seems like a rather cool machine, though: Single osc with sub-osc, 15 filter
modes, self-oscillating filter, more modulation routings than you could shake
a stick at, AD, AR and ADSR envelopes, and a semi-modular construction.
Controlled by 1v/oct cvs and +5 gates and with a planned extension kit to
bring out all the patch points to the top of the unit, turning it into a
normalized modular. The Mix even had a demo song on the CD, which sounded
like someone making acid farting noises for three minutes :-( but I believe
that to be an effect of The Mix's demo programmers rather than a feature of
the synth :-) Construction is all discrete and surface mounted.  Then, nobody
heard anything again. What a pity. Then again, this Geoff fella spoke about
maintaning a low profile, so perhaps that's what he's doing. Somebody should
call him and find out. /Moxie (Digging through the shelves)
