re re 440 help!
re re 440 help!
2000-04-23 by revtor@aol.com
Paul B wrote.....
so the noise is created by the input section of the filter
what happens when you adjust the input attenuators - can you tie it down to
one input only..?
--->Nope, the input knobs have no effect on the noise...
what happens when you adjust the resonance control - does that affect the
noise level..?
--->The res just acts normally, like turning up the res with any other
filter.  The noise level stays put.  Its as if I had noise going into the
filter.
is the noise pure white noise (like what comes out of the MOTM100) or is it
a rough modulating noise..?
--->The noise sounds pretty damn pure.  Unwavering.  Sounds white.  Maybe a
little off white.. ; )
the module isn't now two spaces closer to an ambient noise source is it..?
(ie huge power supply / computer monitor / radio transmitter / ufo)
--->Yeah I moved the module 2 spaces closer to my 900ps.  But this shouldn't
affect MOTM at all.  And since then I've had it out of the rack and it still
hissed away...
that's all i can think of for the time being - hope it helps
--->Thanks..  Its on it's way to Paul.  Im dying to know what happened.
cheers
paul b
--->cheers
--->steve m
