> -----Original Message-----
> From: David Bivins [mailto:dbivins@...]
> Sent: Tuesday, April 18, 2000 12:36 PM
> To: motm@egroups.com
> Subject: RE: [motm] silly question
> I see your point, but--
> Don't you already have voltage control over frequency on your 420s?! You
> should have three inputs that will control the cutoff frequency
> via voltage,
> labeled: 1V/OCT, FM1, and FM2. What you *don't* have is voltage
> control over
> resonance amount. You do get that (as well as cutoff control) on the 440.
> I don't know the technical answer to your question, but having
> asked similar
> questions on AH awhile back and getting learned responses from
> the likes of
> Kevin Lightner and probably Paul too, the answer is no. With some circuits
> it might be a simple matter, with others, not a simple matter. So there
> would be no "generic" approach that would work.
> David.
> > From: Nathan Alan Hunsicker [mailto:nate@...]
> > Sent: Monday, April 17, 2000 8:29 PM
> > To: MOTM Newsgroup
> > Subject: [motm] silly question
> > Is there any simple circuit that could be made to permit voltage control
> > over any pot? My question probably doesn't make much sense, and with my
> > limited electrical knowledge, I probably won't explain it very well
> > either. What I was thinking of was a circuit designed to simulate a
> > pot. A simple circuit with a CV in, a CV attenuator, and 3 wires to
> > replace the pot, 2 to provide a constant resistance and one to vary
> > according to CV. This would be a simple solution to those of us who want
> > voltage control over the freq. on their MOTM-420's or the wet/dry
> > control on a spring reverb. Maybe I'm out of my mind here, and this is
> > an impossibility, but it's worth throwing out. Let me know if it's
> > possible or if it would involve too much circuitry. -Nate
> > Calling all Jazz fans. Check out DownBeatJazz.com's Digital Downloads
> > section where you can download free mp3s. If you're a musician, upload
> > your songs to DownBeatJazz.com for a chance to get reviewed by Down
> > Beat Editors!
> > http://click.egroups.com/1/2142/3/_/529958/_/956024824/
> Your high school sweetheart-where is he now? With 4.4 million alumni
> already registered at Classmates.com, there's a good chance you'll
> find her here. Visit your online high school class reunion at:
> http://click.egroups.com/1/3139/3/_/529958/_/956071955/
