RE: [motm] Excel Question (only slightly off-topic)
2000-04-19 by Tkacs, Ken
Aha! Thanks! I'm working on a spreadsheet (obviously); I'll post a link to it when I get back to it... others may find it useful.
Sent: Tuesday, 18 April, 2000 6:29 PM
To: motm@egroups.com
Subject: Re: [motm] Excel Question (only slightly off-topic)
Finally a question I can answer!!!
=POWER(2*B4,1/12)
(I'm assuming "two' of the cell above it" means 2 times the cell above
it...)
If this equation is in cell B5 then B4 represents the cell above it!!!
Power(a,b) is the excel funtion that raises a to the b power... Power(2,3)
would return 8, Power(2,4) would return 16...
To get the root of a number you would invert b and write it as
Power(a,1/b)... Power(16,4) would return 2... 2 is the 4th root of 16...
If you wanted the root of 2 of 'a' you would write the equation
Power(2*a/1/b)
Okay, I'm boring myself!!!
Go ahead and plug numbers in the attached little excel speadsheet and have
fun...
If it's not quite what you're after go ahead send the equation and I'll be
more than happy to work it out for you!!!
Good Luck...
Al (failed all my english classes) Wagner
Get a FREE Virgin backpack-style Bag with EVERY order!
http://click.egroups.com/1/3000/3/_/529958/_/956096939/
