Paia Hot springs reverb.. behind a 2u panel??
2000-04-16 by Tkacs, Ken
I have two Hot Springs kits that I built when they first came out. I intend to put them into true MOTM physical format (some day... have a lot on the table right now). I can't guarantee that Paia hasn't changed anything since I bought mine, but for one channel, the PCB is 3" x 3" and the reverb tanks are 3.25" x 9.25". There are two reverb tanks per kit; they connect to the PCB with coax cable. My intention was to mount the PCBs behind a 1u panel (I am probably going to mount both kits into one module to make it 'dual' or 'stereo'). Originally I was going to put the spring tanks in an enclosure on the floor with lines running to them, but now that I'm leaning toward angled cabinets, there would be enough room inside along the back to house the tanks internally. Just have to stack them (not directly--they're open on the bottoms...would build a mini wood shelf to stack them). Maybe putting some grounded sheet metal around them would cut down interference from the other electronics; I'll have to play with them when the time comes to see if it's a problem. I imagine the power supply is the thing that would most interfere with them. Also note that the Hot Springs reverb circuits provide straight, "wet" reverb. I will probably put some thought into building some kind of output mixer to mix the wet & dry signals. Should be a simple enough circuit... haven't thought about it yet. Also haven't looked to see if there are impedance issues. I used to run the HS's off the effects bus of my Portastudio...may not be hot enough for direct MOTM integration (?). That way a 1u panel will have two knobs (wet/dry per channel) and four jacks (A & B IN & OUT). No reason to go 2u on this one since there's no way you're going to keep the tanks directly behind the panel. Gotta mount them at least a little bit away inside your cabinet. Unless you have a real deep cabinet and a very wacky bracket system in mind to attach them to the front panel... hardly seems worth the effort. I haven't even fired these babies up in ten years; I'm just assuming they still work! But I remember being pretty happy with them when I got them, very smooth for spring reverb. They just sound like warm 'space' and don't have much twang at all. I threw them in the closet once digital reverb became affordable, but now I miss them. And good ol' spring reverb is part of the classic analog modular sound, no?
-----Original Message----- From: revtor@... To: motm@egroups.com Sent: 04/15/2000 10:34 PM Subject: [motm] Paia Hot springs reverb.. behind a 2u panel?? Guys, I want to build a spring reverb module and am looking at the Paia Hot Springs as the only kit reverb out there.. I (of course) want to build it behind a MOTM panel so It is fully compatible with my system. Do any of you who have built this or know the dimensions of the reverb tanks think that they and the circut board and the jacks and pots needed will fit behind a 2u panel.. 3u?? All I need to know is if anyone thinks that this is possible.. Then I'm going to order the kit. I know I can make it work but any real info would be helpful. I should keep spring reverbs away from power supplies right??
