Paia Hot springs reverb.. behind a 2u panel??
2000-04-16 by revtor@aol.com
Guys,
  I want to build a spring reverb module and am looking at the Paia Hot
Springs as the only kit reverb out there..  I (of course) want to build it
behind a MOTM panel so It is fully compatible with my system.  Do any of you
who have built this or know the dimensions of the reverb tanks think that
they and the circut board and the jacks and pots needed will fit behind a 2u
panel..  3u??   All I need to know is if anyone thinks that this is
possible.. Then I'm going to order the kit.  I know I can make it work but
any real info would be helpful.  I should keep spring reverbs away from power
supplies right??
~Steve
