Re: [motm] Joystick
Re: [motm] Joystick
2000-04-13 by jhaible
> did you mount your joystick on a vertical panel in the main cabonet, or in
> an auxillary box?
You have hit the weak point. (;->)
Mounted in the main cabinet, I rarely use it. Too far from the keyboard
to reach it comfortably. Some day I will fix this.
(the problem is actually more complicated. I use my OB-8 as a keyboard
for the JH-3, so there is some distance between the modular front and the
keyboard. The OB-8's frontpanel and the modular for a nice L-Shaped
user interface together, but the joystick is placed too far from my left
hand.
JH.
