RE: [motm] Purchasing decisions
2000-04-05 by Brousseau, Paul E (Paul)
I'm not quite clear... how is this different from a band-pass filter with
modulated Q / width and frequency?  Not that it wouldn't be really cool, I'm
just wondering if I'm missing a nuance?
--PBr
> -----Original Message-----
> From:	David Bivins [SMTP:dbivins@...]
> Sent:	Wednesday, April 05, 2000 9:10 AM
> To:	motm@egroups.com
> Subject:	RE: [motm] Purchasing decisions
> Just think of how much fun (and how
> useful) it would be to control both of those expressive elements at once!
> Consider multiplying a keyboard tracking CV and inputting it into FM1 of
> each filter, with a slightly different offset on each; how about the same
> patch but with a lag processor between one of the CVs and one of the FM
> inputs! I'm salivating.
2000-04-05 by Dave Bradley
With a resonant highpass and resonant lowpass hooked in series, you get 2
resonant peaks at the corners, instead of 1 in the center for a single
bandpass. Also, you can control the cutoffs separately, like have an LFO
modulating the HP but an envelope modulating the LP.
Plus, if you hook the 2 filters in parallel, then you can get 12 db/oct
notch filtering, doubly resonant peaks if both are set to NF, etc. Just a
lot more flexible.
Dave
> From: Brousseau, Paul E (Paul) [mailto:noise@...]
> Sent: Wednesday, April 05, 2000 12:35 PM
> To: 'motm@egroups.com'
> really cool, I'm
> --PBr
RE: [motm] HP and LP vs single bandpass
Old programming trick:
Beef up a patch with wimpy sounding bass by running through an additional
highpass filter, with no modulation and a low cutoff frequency around 50 to
100 Hz. Turn up the resonance to add a bass boost to fatten up your patch.
Dave
> True. I hadn't thought of the extra resonance peak. But you could
> replicate
> the separate cutoff frequencies, couldn't you? There is a
> specific interval
> between cutoff frequencies at any given point in time (width) and by
> carefully choosing the center point (i.e. bandpass frequency) you could
> probably come close; but given what Dave pointed out, it really wouldn't
> sound the same at all unless you kept the filters wide open in all cases.
> Interesting. This is the kind of stuff I love to think about but shouldn't
> be thinking about while at work! :)
> > From: Dave Bradley [mailto:daveb@...]
> > Sent: Wednesday, April 05, 2000 11:48 AM
> you get 2
> etc. Just a
> > lot more flexible.
> > Dave
> > filter with
> > > really cool, I'm
> > > --PBr
> > LOW RATE, NO WAIT!
> > Get a NextCard Visa, in 30 seconds!  Get rates
> > as low as 2.9% Intro or 9.9% Fixed APR and no hidden fees.
> > Learn more at:
> > http://click.egroups.com/1/937/3/_/529958/_/954957057/
> LOW RATE, NO WAIT!
> Learn more at:
> http://click.egroups.com/1/937/3/_/529958/_/954957417/
2000-04-05 by David Bivins
No, I think you have it. That's pretty much what I'm describing I guess. Of
course, we don't have a MOTM band-pass filter with modulatable width, so...
But that's a very good point.
> Sent: Wednesday, April 05, 2000 11:35 AM
> really cool, I'm
> --PBr
> elements at once!
> about the same
> PERFORM CPR ON YOUR APR!
> Get a NextCard Visa, in 30 seconds!  Get rates as low as
> 0.0% Intro or 9.9% Fixed APR and no hidden fees.
> Apply NOW!
> http://click.egroups.com/1/2121/3/_/529958/_/954955989/
True. I hadn't thought of the extra resonance peak. But you could replicate
the separate cutoff frequencies, couldn't you? There is a specific interval
> lot more flexible.
> Dave
> filter with
> > really cool, I'm
> > --PBr
> LOW RATE, NO WAIT!
> Learn more at:
