Re: Joysticks, 440, Nord Modular
2000-03-31 by mark scetta
dave, i don't have any power going to my pots, i'm using them as remote
versions of the pots on the front panel. my question: are you hooking +15
up to them? why?
for the trigger button, i lowered the voltage down to ~ 7.38v by taking a
friends recommendation and putting four 4.7k 1/2watt resistors in
parallel&serial as such:
ground ----+ ! +---- +15v
~ +7.38v
i would still like to hear from the group: what is the best trigger voltage
to use?
so this is not verified yet, but here's my wacky wiring in full:
the trigger button has 2 contacts. on mine, both are hooked to the tip of a
1/4" phone plug. this gets plugged in to the jack on my preamp module with
the 7.38v (my resistors are soldered into a separate, unused portion of the
preamp's PCB). another switchcraft jack is wired tip-to-tip with this one
(so there are 2 jacks involved, mult'ed, if you will.): plug the phone jack
from the trigger button into one of them, and use a patch cord to send the
signal to a desired module.
there's probably an easier way, like mounting a 9v battery inside the
joystick, but this should be fine for me.
mark
At 04:50 AM 3/31/00 +0000, you wrote:Show quoted textHide quoted text
> >>From: mark scetta <n0nspaz@...> > >> > >>yes this is what i'm doing with the PC Jr. joystick, leaving the cord > >>length to use it remotely (not housed in a module), just cutting off the > >>end connector, removing the internal capacitors and bringing the X & Y > >100k > >>pot outputs to 1/4" neutrik plugs. i have not yet determined if i'll > >want > >>to put trimmer pots on them. it's working so far. > >> > >>the FIRE button (oops i'm shouting 'fire' in a small room) will go to > >a > >>custom 1/4" jack in my MOTM custom preamp module, wired to +15v thru a > >>couple of resistors for use as a trigger button. can anyone recommend > >what > >>voltage i should use for this? i was thinking that 7v was a nice > >>compromise. (?) > >> > >Based on your message, I did this with mine, cut the end off the joystick > >and wired it to the +15V lead, and the outputs to 4 jacks (X + Y CV out, > >top and front button out). Works great, with a few quirks. First, the X > >voltage decreases as you move the stick left. That is, if I patch it to > >control pitch on a VCO, the lowest pitch is at the far left and the highest > >at far right. This seems counter-intuitive, but workable, I can always > >patch it through an inverter.
