Re: [motm] Router Weirdness
2000-03-11 by Paul Schreiber
12:0 (up) is ground. Install a jumper wire from the beveled lug (ground) to
top lug of the CV IN jack. I bet that does the trick!
To: <motm@onelist.com>
Sent: Saturday, March 11, 2000 3:44 PM
Subject: [motm] Router Weirdness
> From: "Tkacs, Ken" <ken.tkacs@...>
> I have a question regarding my MOTM-700 Router's operation.
> The whole module seems to "work." The strange thing about mine is that,
with
> nothing plugged into it, the upper half seems to switch at about -1.9,
> whereas the bottom half switches at 12:00 exactly. If they were the same I
> wouldn't question it. There is no calibration to speak of on this unit.
> All I can think is that DC is leaking in somewhere, or a resistor is
wrong.
> I checked the resitors... they look right...
> Anyone have any sage counsel?
> Of the nine MOTM kits I've built so far, this is the only one that hasn't
> worked perfectly first time. Even so, it "works," but it seems that
> something is just off a little bit.
> Thanks in advance.
> MAXIMIZE YOUR CARD, MINIMIZE YOUR RATE!
> Get a NextCard Visa, in 30 seconds!  Get rates as low as
> 0.0% Intro or 9.9% Fixed APR and no hidden fees.
> Apply NOW!
> http://click.egroups.com/1/2122/2/_/529958/_/952811523/
2000-03-12 by J. Larry Hendry
Another thing to check is R10 and R11.  If these are not the same size,
that could skew the center point of VR1.  Larry H
> beveled lug (ground) to the top lug of the CV IN
> Paul S.
> From: Tkacs, Ken <ken.tkacs@...>
> operation. The whole module seems to "work." The
> strange thing about mine is that, with nothing plugged
