VC Divider is...ALIVE!!
2000-03-11 by Paul Schreiber
Attached are some of the VCPD outputs as shown on a HP1662C logic analyzer. The input clock is 5Khz (it will work up to 18Khz before funny stuff happens). As you can see, the outputs are all happily dividing. The 'N' is 11 in this example. 'N' can range from 2 to 33. As I said before, there are mechanical issues to resolve, but this will be an easy kit (easier than a '120). The only mess is that is does have *13* jacks to wire up. No price yet: but not exceeding $170. Note that ALL outputs are available *simultaneously*! That little PIC is humming along at 40Mhz! Paul S.
