Joysticks - what I've found
2000-02-23 by ivancu@aol.com
I've dissected a few joysticks that I recently purchased.  One was quite
nice; four center-tapped 50K-ohm pots.  $4.50 each.  Unfortunately I got the
last two.  Ah well.  Another was a little odd; 40K on one axis, 46k on the
other.  $4.95.  Both of these were "raw" joysticks - no package or wiring
around them.
This next one is a "packaged" joystick and is intruiging, and to make the
deal even better, when I opened the boxes (I purchased two) each box had two
units:
CONTROL JOYSTICK has two 150K ohm vari-resistors and "FIRE" button. 1.3"H
metal control stick; no spring "return". 8\ufffd cord w/ DB-9 connector
2.5x1.4x3.5. #MA8699, NEW. $5.00
http://www.fairradio.com/monroe.htm
There are five pins on the DB9.  Two of the pins are the switch on the "Fire"
button, there is a common between the two 150k pots, and then a separate wire
to each pot wiper (also wired to the other terminal of the pot).  Very easy
to open up and modify.
Another "packaged" joystick is a CH Products Mach II.  These are common PC
joysticks from a few years back and can be found on eBay and at swap meets
for not much money.  The Mach III is the same thing with a "fire" button on
the joystick itself.  I prefer the Mach II which has two buttons on the
housing.  The one that I got has a weird connector on the cable since it is
for a PC Jr.  An interesting feature is that there are center-return on/off
switches for each axis; very cool.  There are also trim pots for each axis.
Another plus.  A little more care is needed opening up this package, but easy
to work inside once upon.  One pot measured 148K, the other 160K.  There is a
separate wire to each pot, and then a third common connecting the two.  There
is a wire to each switch and then a third common between those.  This one
looks like a winner; the PC version with a DB9 would be great.
Ok, that's all I could find for small, inexpensive joysticks.  Let me know
what you find!
Ivan
