Glamourous MOTM design
2000-02-17 by Paul Schreiber
Well, here is the exciting result of 12 hours of MOTM-440 parts placement! About 1/2 way done. Will be able to start routing this weekend. Placement is about 75% of the work. See all the parts with 'X'? That means there were duplicates from Copy..commands, so I have to assign a temp value, then go back one at a time and edit the part, then overlay the text in the correct spot (the CAD tool plops it down closeby). Then..I have to place the parts "on grid", which is a 25mil spacing, so that when I route, there is clearance inbetween pads. MOTM is tough becaise I don't route between IC pads (because I'd rather use 80-mil pad diameters for solder ease). Of course, I try not to think about stuffing all those bags with all the parts! I look forward to a slew (PUN) of simpler modules after this one. Paul S. [This message contained attachments]
