RE: VC EGs (whiz bang? How about MoaEG)
2000-02-03 by JWBarlow@aol.com
First I must heartily apologize to Roy. I didn't read his post (below) thoroughly enough to see that he had only mentioned the 15 pot idea as ONE option, and that an option similar to what I was thinking of immediately followed. Sorry Roy! I've got to read more closely. Here's what I'd imagined: Three pots (or encoders): 1) VC IN (per stage). 2) Time to end point. 3) Set end point (voltage). Next/Prev arrows (similar to what Roy describes below) to select the stage. Some way to select the degree of the exponent for a change of state (I'm not exactly sure how the to describe the attack portion of a typical EG -- exponential with reverse orientation)? Moe and I will like the "whompass" (and more!) attack stages that are readily available. How about 8 LEDs (one for each stage) -- changing at the rate of the voltage of that stage in a smooth and soothing fashion. I think this would be a great module, and not difficult to operate or overly expensive in any way. I know several people didn't like the notion of using uP in their analog, but I'd still like to think about this in addition to the current VC EG. I still like the VC DADSR idea too! JB In a message dated 2/1/2000 12:44:49 PM, roytate@... writes:
>It would HAVE to have a gate-detected indicator LED at least, and you >could flash that when it changes stages. My latest (2 year old) idea >for a multi-stage EG consists of a series of 8 stages, with each stage >having 3 parameters: ramp-to voltage, ramp rate and sustain switch. >The ramp-to voltage and ramp rate allow various timings and slopes, and >the sustain switch causes the processor to stick on that stage until >it detects a gate off. I planned on using a PIC chip as a controller >for JH's VC EG idea using 2 NPN and 2 PNP transistors. This seemed to >be easier than using a DAC. I would use a window comparator to determine >when to change stages. This is quite similar to the Roland MKS-50 EG, >only extended beyond ADSR. > >I would LOVE for something like this to become a MOTM module! > >I would envision a multi-stage EG as having 15 or more knobs and >6 sustain switches; or 2 rotary encoders, 3 push-buttons and >an LCD panel [add 8 jacks for voltage controll]. The buttons would >be next/prev stage and sustain toggle. You could also use the >next/prev buttons as next/prev feature if you added several parameters >to each stage. > >The 16 knob variant starts sounding like a sequencer doesn't it? >Either way, a PIC controller tied to an analog VC-EG stage would >allow for voltage control without worrying about stepping. > >Either way, I'm not against your idea, and in fact would like to >have one. You could add a gate delay, and a punch option to a >digital EG quite easily. And for what it's worth, I vote for >using a PIC since I already have a PIC programmer. >
