Re: sustain - time or level - ?
2000-02-03 by DAVEVOSH@aol.com
In a message dated 00-02-02 21:23:55 EST, you write: << 5) I have to differ with Dave V.'s point about having a sustain length control. I think controlling the time domain of the sustain parameter would be more easily be done by controlling the length of the incoming gate signal. I should also mention that I tend to prefer varying gate lengths over static ones anyway since it sounds more natural to me -- there is an interesting take on this in the Digisound schematics though which uses a CEM 3310 to make the sustain have a decaying contour similar to a piano I think. 6) I am interested in Hugo's idea of a peak length control since I've done the tiniest amount of experimenting with this and found it to be a very powerful tool as he suggested! I'm not sure this warrants a pot, however, possibly a three position switch -- anybody have any useful ideas about this? Finally, I haven't finished with the Crow, Roy, Hugo, et al. super whiz bang >> john, well, at least i know now that someone saw my comment about a "time" sustain function as opposed to the standard "level" sustain function! :^) this is probably one of those cases where evryone is right. your points about sustain as a function of gate length are well taken. still, a true "time" sustain still seems useful to me ( didn`t steiner-parker have this feature on their eg unit ? ) - hit the unit with a trigger or gate and it cycles thru the set attack, decay, sustain and release times. now, too, this sort of feature would be restricted to the complex ( read : expensive ) vc dadsr module. might even be switch selectable so you could have a choice of either type of sustain function ( paul - ??? ). there is still a place for the simpler eg`s everyone has been discussing here! the peak idea seems very worthwhile to look into, also! best, dave
