Devastating Bass
Devastating Bass
2000-01-31 by David Bivins
In my continuing quest for loud, obnoxious sounds to use in my crappy techno
music, I came across this:
TB-303 CV out -> MOTM-420-1 (self-oscillating) 1v/oct in
MOTM-420-1 out -> MOTM-120 (square) A in
TB-303 (sawtooth) headphone out -> MOTM 120 (square) B in
MOTM-120 out -> MOTM-420-2 (hi pass, cutoff low, res high) in
MOTM-420-2 out -> MOTM-110 in
TB-303 gate out -> MOTM-800 in
MOTM-800 neg out -> MOTM-420-2 reversed FM1 in
MOTM-800 pos out -> MOTM-110 CV in
You get a solid, buzzy bass out of the second 420 in high pass mode, but the
resonance adds a very deep rumble to the whole thing. Sounds like someone's
coming down the beanstalk for you!
I was inspired by a recent Analogue Heaven post talking about using the
Yamaha CS resonant filters in high pass mode for bass.
I know, I know. I need to buy a couple oscillators, 'cause I'm not doing
anything special here. But it sounds so good!
Re: Devastating Bass
2000-01-31 by Paul & Alleyne
hello all
and a big thanks to david for the last hour of patch mayhem...
>From: "David Bivins" <dbivins@...>
techno
unfortunately i only have one #420 so my version came out as follows:
MC202 CV out > #420 v/oct in (freq 2 or 3 / self oscillating / fm1 -1)
#420 out > #120 A in (square)
MC202 sawtooth out via headphones > #120 B in (square / #120 in cross mode)
#120 out > #110 VCA in
MC202 gate into #800 gate in (attack 3 / rel 3)
#800 pos out > #110 CV in
#800 neg out > #420 FM1
now tune a #300 to the source sequence
multiple the source gate into a frequency divider (i built one myself and
i'm still suprised it works) put a suitable division into the lfo sync in
then:
lfo pulse out > #700 cv in
#300 sine out > #700 input a or b
#700 out x > #420 audio in (mix 8 upwards)
congratulations - you have now made something that sounds annoyingly like a
DJ on a bad scratch day
things went horribly wrong when i started messing around with the S&H...
amazing what you can do with a modular isn't it..?
cheers
paul b
