Rail vote
Rail vote
2000-01-31 by Paul Schreiber
Please voice your opinion for "big honkin' rack rail" lengths for wood
cases.
1 26U length recorded. Any other preferences?
The rail are currently planned as simple 'L' brackets with:
a) the same tapped holes/spacing as the 19A but....
b) the other "leg" of the rail is 0.75" wide with counterbored holes to
accept wood screws
The holes on this side are about 6 inches apart.
I *know* this does not address what to do if you want 2 or more "butt-ended"
rows
on top of each other. One solution is a "semi-floating" rail, 1.00" high
with 2 parallel
rows of tapped holes. One the ends, there is a 90 degree bent flange with
say 4 counterbored
holes for wood screws. This allows the bottom panel holes of "Row A" and the
top panel holes of
"Row B" to screw into *something* that is supported on the ends (since the
ends screw into the
left/right sides of the case).
Also, these will be "cut in half" so I can ship them without sending 40"
long torpedos
through the mail system, and then postal employees use them for pole
vaulting practice.
I am assuming a 2 row by 'N' length (N to be beat to death) is what people
are looking for.
Now, *sloping* a la Moog 35/55 is another issue! I seriously doubt I can
provide angles bent other
than 30/45/60/90 (I think the Moog slope is about 10 degrees). Moog used
*wood* rails, which
with any dado machine you can just "dail in" the bevel slope. Bending 11ga
iron bars is a different
animal!!
Really, how often do you plan to move around/swap modules in the big honkin'
case?
From my end: I have to watch stuff like maximum UPS/USPS/FedX dimensions!
Unless you
want to pay $120 for Yellow Freight.
I *think* a "road case" like 18U wide by 2 rows tall by 9" deep is
'UPS-able' in a double box. Need
to check. Power supply in rear, you have room for 18 2U wide modules. About
the size of my Fender
Super Reverb amp!!
Re: Rail vote
2000-02-01 by Paul Schreiber
> Cast one vote for 24U length.  I guess I could cut down  from 26U.
Oh, come on! You can use 2 more VCOs!
> Explain to me why this does not allow one to bolt the big honking rack
> rails back to back for "butt-ended" rows one on top of another.
There is no end support. And, not everyone relishes the thought of drilling
11 gauge steel.
> That might be OK depending on the answer to my above question.  If I were
> planning to "butt-end" two rows on top of one another, or bolt top and
> bottom rows to some kind of "magic bus," I would want my joints to be
> staggered, not in the middle.  For the 26U example above.  I would want
say
> one 16U and one 10U length so the but would not be at the same point on
> both crossing rails.  However, if the answer to above says they cannot be
> "butt-ended" this is a non issue..
I don't want to have 2 different part numbers (short one/long one) to keep
track of.
Call me lazy.
Re: Rail vote
2000-02-01 by J. Larry Hendry
> From: Paul Schreiber <synth1@...>
> lengths for wood cases.
> holes to accept wood screws
> or more "butt-ended" rows on top of each other.
rails back to back for "butt-ended" rows one on top of another.  That is
certainly possible with the existing rack rail "L" brackets (some drilling
required). There is nothing I can see about the extra depth that would
cause a problem.  All that would be required is the same bend profile.
Would the bend be different?  'Splain it to me Lucy."
> without sending 40" long torpedos through the mail
> vaulting practice.
staggered, not in the middle.  For the 26U example above.  I would want say
Larry Hendry
Re: Rail vote
2000-02-01 by JWBarlow@aol.com
In a message dated 1/31/2000 4:46:20 PM, synth1@... writes:
>cases.
I'll take any size between 22U and 26U.
>accept wood screws
I hope the same "tight" radius as well!
>rows
>with 2 parallel
>say 4 counterbored
>the
>top panel holes of
>the
>ends screw into the
If I understand this correctly, then this is a very similar solution to the
one I was thinking about.
>long torpedos
>vaulting practice.
I understand that there may be certain length limitations for shipping BUT
I'd like to keep my rails as long as possible.
>*wood* rails, which
>animal!!
It seems that any mounting solution that would work for a middle pair of
butted rails would work for a sloped cabinet -- or, as implied by your
mentioning of the Moog cabinet, a wedge could be cut for top and bottom
mounting rather easily (though I couldn't do it here). I seem to remember
Paul S. was thinking of putting case plans together so that each of us could
either build the case or have a carpenter build it for us. I think many of us
could pool our resources in this manner to come up with some common
dimensions at least.
Just a note that the 22U rails I got from TechAM were sent UPS (in a simple
cardboard tube I think).
When might these be available (and how much are we thinking of paying)?
John B.
