Index last updated: 2026-04-02 23:24 UTC
Using VCA + ADSR for VC-ADSR
2010-03-17 by Argitoth
Has anyone expirimented with this? This will not give you the same
behavior that a true VC-ADSR will give you. Depending on your
settings, the decay slope will become faster... (or is it slower?)
depending on how fast you trigger the envelope. It gives a varying
decay slope (depending on the settings) that will add a human-like
touch to the sound.
www.elanhickler.com
Re: [motm] Using VCA + ADSR for VC-ADSR
2010-03-18 by Kenneth Elhardt
> touch to the sound.
It's hard to understand clearly what you're saying because you don't specify
how you're connecting things. Is it the gate that's going through a VCA and
then into the gate input of the ADSR and you're able to control the length
of the gate in some way? Of course the length of gate and to some extent,
the decay time can be controlled by how long a key is held down anyway. Not
fully understanding.
-Elhardt
