Re: speculative modules
2000-01-26 by DAVEVOSH@aol.com
In a message dated 00-01-23 20:25:25 EST, you write: << Sheppard function generator, quadrature oscillators, wavetable oscillators, through-zero FM oscillators, >> dave, should paul ever get around to offering them, from past experience of having them in the late, lamented s**** i had, a through zero vco is really cool. i was getting to the point where between that and regular fm, i wasn`t even using the "normal" vco waveforms. i also had a p*** kit that i had built for a shepard function generator and it was a lot of fun. not just for the "name" effect but also worked as a quadrature oscillator and made a great modulation source in general - use out 1 to drive a vco and 8 to drive a vcf ( really simple example ) and get an eccentric sort of modulation. i liked the effect. best, dave
