Re: [motm] Soldering Technique
2009-03-02 by George Kisslak
Made these purchases made back in 2001: Mouser: 591-300 Panavise std base 19.99 591-315 Panavise circ brd holdr 29.99 591-312 Panavise tray mount 19.99 Digikey: 1 PANAVISE WIDE HEAD 538 366PV-ND 30.99 1 PANAVISE VACUUM BASE 538 380PV-ND 31.99 George p. hendricks wrote: > which model? > thanks! > -phil > > On 3/1/09 6:14 PM, "George Kisslak" <groovyshaman@...> wrote: > >> After I built my 1st module the 120 back in 2001, I got a Panavise and have >> never looked back. I don't do the 90-degree-crimp/snip/solder. I do the >> 60-degree-bend/solder/snip. Has worked perfect for me. Can do about a >> dozen components at a time, until leads start to interfere with each other. >> I also bend IC pins 60 degrees and do multiple ICs at once. I hover with >> the iron less that 2 secs on a polystyrene cap leads and don't do the other >> lead until after 10 secs (rotate around). Same technique for ICs. >> >> George >> >> Richard Brewster wrote: >>> I've heard the term 'crimping' used to describe what I do, but I >>> understand your meaning. I do fold the leads 90 degrees to lie flat on >>> the board and then cut them before soldering. I've never found this to >>> be a problem for desoldering. A good quality solder wick will suck up >>> all the solder and leave the wire easily lifted. (Is there a good video >>> on desoldering, I wonder?) Then again, I've done a lot of circuit board >>> repair, so maybe it's not as big a deal to me as to a novice. Replacing >>> a resistor or capacitor is isn't that difficult, especially if you have >>> a Panavise (http://www.panaviseonline.com) for holding the board. The >>> alternative is to make a 45 degree bend in the leads, cut them and >>> solder. The drawback to this technique is that you have to do one >>> component at a time. >>> <snip>
