Is 22gage stranded wire acceptable?
2009-02-28 by Argitoth
Hey, I found 22gage stranded wire at radioshack. Is this acceptable if
I run out of Paul's wire? Or should I seriously look for 24 gage?
www.elanhickler.com
Re: [motm] Is 22gage stranded wire acceptable?
2009-02-28 by Paul Schreiber
MOTM kits use 22ga wire. Be careful with the RS wire: make sure it is
*tinned*, stranded wire (is silver in color). Do NOT use untinned wire, that
is *very difficult* for a beginner to solder.
To: <motm@yahoogroups.com>
Sent: Friday, February 27, 2009 8:20 PM
Subject: [motm] Is 22gage stranded wire acceptable?
> www.elanhickler.com
2009-03-01 by Argitoth
I found some wire for less than $6.00. Why is all the wire over $25 at
mouser.com? Does this $6.00 wire suck or something? Or is it good for
MOTM projects?
Link: http://www.allspectrum.com/store/product_info.php?products_id=2756&osCsid=12105adeaef305e814681f65ef00e3d3
RE: [motm] Is 22gage stranded wire acceptable?
2009-03-01 by John L Rice
I'm not sure about that particular brand, it could be fine . . or not.  I
read some negative reviews of Radio Shack wire that the insulation melted at
lower temperatures and shrunk more than was acceptable. I bought some
anyway. Yeup, those people were right, it isn't very good wire!
Some good stuff I found at a reasonable price at a good dealer is NTE
stranded hookup wire from TriState Electronics:
https://www.tselectronic.com/nte/wh_wire.html
FYI: below is my order from January:
Qty.   Part No.      Unit Price  Price       Description
 1      8216-100-10       39.60     39.60  RG174/U 50 ohm Transmission and
Computer Cable
 1      WH26-00-100        7.25      7.25  26 ga. Stranded Black  100ft.
Hookup Wire
 1      WH26-09-100        7.25      7.25  26 ga. Stranded White  100ft.
Hookup Wire
Subtotal                         $    54.10
Shipping                         $     8.95
Total                            $    63.05
John L Rice
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
Argitoth
Sent: Sunday, March 01, 2009 11:44 AM
To: motm@yahoogroups.com
Subject: Re: [motm] Is 22gage stranded wire acceptable?
MOTM projects?
Link:
Yahoo! Groups Links
2009-03-02 by Argitoth
The wire I found, the Consolidated Wire has a homepage:
http://conwire.thomasnet.com/category/hook-up-wire
Apparently they have all kinds of wire in all colors, but do they sell
to individuals like me? I'll call them monday and find out.
On Sun, Mar 1, 2009 at 4:53 PM, Tom Farrand <mbedtom@gmail.com> wrote:
> Good catch!
> I looked up the specs on the white wire and assumed all were in the same
> series.  Not so.  Yes, the "good" wire, as you stated, is only available in
> the three colors.
> Then there is http://www.asapwire.com/ which carries the "good" wire in all
> colors and has it on 500' spools.  A wee bit more expensive per foot than
> All Spectrum but they claim to carry all the colors.  But they do not
> actually identify the manufacturer of the cable and that makes me a bit
> nervous.  I think I will hold off on making a mass purchase.
> John Rice reported buying wire from Tristate.  Tristate is a business I pass
> twice a day.  I bought 10 spools of their wire for work, and it is decent
> enough wire.  But, they want $10 a 100' spool which I think is still too
> high.
> Yes, I think I will mull this over a bit before I bite.
> Peace.
> Tom Farrand
> On Sun, Mar 1, 2009 at 3:07 PM, Argitoth <argitoth@...> wrote:
>> Hey Tom! Be careful about getting the right model of wire. There's the
>> UL and the UL1015. UL1015 is the better of the two but only comes in
>> red, black, and white. The link goes to UL1015. Here's the parts:
>>  CONWIRE-866-0 (Black)
>>  CONWIRE-866-2 (Red)
>>  CONWIRE-866-9 (White)
>> Here's Consolidated Wire homepage for Hook-up Wire:
>> http://conwire.thomasnet.com/category/hook-up-wire?
www.elanhickler.com
2009-03-02 by Richard Brewster
Here's another place I bought wire.  I walked into Unicorn Electronics
in Johnson City, NY, when I was there visiting a few years ago and got
ten 100-foot rolls of 22 gauge hookup wire.  (Tip:  Buy more black wire
than colors.)  I like the insulation on this wire.
http://www.unicornelex.com/
http://www.unicornelex.com/detail.php?itemno=22-8324&
Here's a photo of a module showing this Unicorn wire in use:
http://pugix.com/synth/catgirl-synth-pulse-divider/
Richard Brewster
> On Sun, Mar 1, 2009 at 4:53 PM, Tom Farrand <mbedtom@...> wrote:
>> Good catch!
>> the three colors.
>> high.
>> Peace.
>> Tom Farrand
>>>  CONWIRE-866-2 (Red)
Re: [motm] solid core vs. stranded? was: Is 22gage stranded wire acceptable?
2009-03-02 by Paul Schreiber
> any reason not to use solid core cable?  as it's easier to work with, no
> tinning? I've also seen it use is many commercial modules.
- stranded wire is MUCH easier to solder
- stranded wire will take 10X the movement that solid wire will. Solid wire
is for fixed installations (like in the walls of your house).
- it's not a good idea to twist solid wire. Twisted wires have a lot less
interference pick-up that individual solid wires
