http://zappa.jpq.com/whatever/JPMODULAR.JPG
The "other stuff" in my MOTM setup (sometimes referred to as the tower of power)
The silver box is a single row of analog systems modules that I picked to provide functions not yet available from MOTM. they were:
-Joystick
-Voltage Quantiser
-VC LFO <----(well, now we have the MOTM320)
-CV buffer / inverter
-Pre-amp, inverter, slew module
-Trigger generator with VC pulse shaper & VC DC level shifter
-Audio and trigger clock divider
-Sequential switch mixer, VCA (similar to ARP 1050 Mix sequencer)
-CV/Audio mixer
The sequencer is an analog systems TH48, a somewhat rare sequencer that's all analog. This is no longer manufactured, but AS does have other new sequencer modules that are similar (if you just can't wait for the motm).
Blacet modules are on top.
Below the motm's there is a moog 12 stage phaser, kenton pro 2000 and a hosa patchbay to bring the connections to the front and also, through some wiring in the back, provides multiples for the kenton outputs.
The keyboard is a Novation MM10 - a great little controller but unfortunately, also no longer manufactured.
Also, just below that are 2 MOTM 900 power supplies. I extended the outputs to power distribution boards tucked inside the rails on either side.
...jp
