New 102 and the TSA destroyed some modules!
2008-02-04 by earthtodylan2000
Paul and the group, The new module sounds fantastic...the CV Record function sound like a blast and with gated record triggers it will be another step in radical glitched out now energy with NO COMPUTER NEEDED. A few questions... 1. With no "LAG" function will you not be able to get smoothed S&H modulation within the module? Not good in my opinion if it's gone. 2. I'm a fan of the "SLOW" out of the 101. I use it to trigger my MOTM-800's to produce intermittent ambience. Sort of a poor man's Noise Ring. Is there a new function that will enable this? On a side note. I just took my MOTM system to NYC to play some shows. They went well especially the one with Eric Copeland from Black Dice! The bad news is the TSA almost totaled my system...taking off the back to inspect for drugs and bomb they plugged in power supplies in reverse, sheared off trim pots and dropped the case causing Spectrol pots to break off at the circutboard. So far 5 modules are wasted and will need to be rebuilt. I'm just glad I did an idiot check before I turned the system on... it would of fried the modules that were plugged in wrong! I'm gonna post a message about it when I get some time. It's a total drag... If anyone has some extra pots they want to donate Im humbled... David Scott Stone www.myspace.com/sirdsssound "Plays The Modular Synthesizer" OUT NOW on PPM! http://www.postpresentmedium.com/home.php?records=ppmrecords
