Triple + Dual vs. bigger Triple power supply
2007-07-24 by Bryce Churchill
2007-07-24 by Paul Schreiber
To: <motm@yahoogroups.com>
Sent: Monday, July 23, 2007 9:00 PM
Subject: [motm] Triple + Dual vs. bigger Triple power supply
> I've begun building a cabinet that will hold 20-25 MOTM modules
> (including an MOTM-650, which the site description says may draw
> 575mA +/-15v). I believe that one MOTM-950 Dual Power supply won't be
> enough for the +/15v side.
> What would be better? Installing an MOTM-900 Dual Power supply
> (outputting +/-15v @ 800mA) *and* an MOTM-950 Triple Power supply
> (outputting +5v @ 3A, and +/- 15v @ 400mA) or... replacing these with
> one upgraded Power-One Triple Power supply (such as model# HCBB-75W-A
> which outputs +5v @ 6A, +/-15v @ 1.5A)?
> Cheers,
> Cecil
2007-07-24 by Stephen Drake
I would stick the Power One HCBB in there.
> Cheers,
> Cecil
2007-07-24 by loopcycle
> I'll second Paul's advice. When recently expanding my cabinet, I subbed outscrew the RIAA. artists, take control.
> the power one unit that came with my 900 with the HCBB version. Make sure
> you know what you're doing before doing this, however. I don't use the 5
> volt output yet, but it's nice to know it's there if needed. Now I never
> have a problem with my 23 modules, including some blacet ones that draw a
> lot of power.
> Steve
> > Paul S.
> > ----- Original Message -----
> > From: "Bryce Churchill" <sunecho@... <sunecho%40sexkult.org>>
> > To: <motm@yahoogroups.com <motm%40yahoogroups.com>>
> > > Cheers,
> > > Cecil
> Stephen Drake
> sduck409@...
> makeme1witheverything@...
2007-07-28 by eric f
I'll second Paul's advice. When recently expanding my cabinet, I subbed out the power one unit that came with my 900 with the HCBB version. Make sure you know what you're doing before doing this, however. I don't use the 5 volt output yet, but it's nice to know it's there if needed. Now I never have a problem with my 23 modules, including some blacet ones that draw a lot of power.Steve
On 7/23/07, Paul Schreiber <synth1@speakeasy. net > wrote:--I would stick the Power One HCBB in there.
To: <motm@yahoogroups. com>
> Cheers,
> Cecil
Stephen Drake
sduck409@comcast. net
makeme1witheverythi ng@gmail. com
2007-07-28 by Richard Brewster
> What is the "knowing what you're doing" end of this. I need to do this...
> thanks,
> eric f
> Steve
