Index last updated: 2026-04-03 18:09 UTC
Re: [AH] Best CEM-3320 circuit : SSM2040/ MOTM 440
2007-06-23 by kheck73@aol.com
I have an Octave Cat SRM with the SSM2040 filter chip, and a MOTM 440
filter. I can vouch for the fact that the 440 filter in the 'normal' mode  sounds
(timbral response) just like the SSM2040 LPF in the Cat. As I use  it, the 440
has a quieter background, although I don't know if that is  purely due to the
filters themselves, or possibly the  VCA and other signal paths in the Cat. You
wouldn't really notice too  much... until you listen to them side by side. I
also notice when the Cat  breaks into resonance at high Q, the oscillation is
louder (but the same tone), and is a bit less controllable at the  breakpoint
than with the 440. The control aspect could be the age of  the synth and the
use of an old slider for resonance on the Cat vs.  the better quality pot on
the 440...I don't know. I haven't really  explored if the two react the same to
overdrive.
The 440 has also has a Bass switch you can flip to 'Enhance'.  This makes the
low end stay beefed up at higher cutoff and  Q (compared to some loss of bass
on the 'normal' 2040). Nice improvement,  and you can always switch back to
the true original response if you want. It's  sort of like the loudness button
on a stereo receiver.
John Blacet did a module back in the '70's called the 'Phase Filter'. I
believe it configured the SSM2040 chip into different filter modes. I wonder if
the MOTM 440 could be modified to do the same?
-Karl.
In a message dated 6/22/2007 1:08:33 A.M. Eastern Daylight Time,
djhohum@... writes:
>  This is hands down, my favorite filter. I wonder if the MOTM 440
>  really sounds like the real thing?
I don't know, it would be  interesting to hear from people who have
tried either the MOTM design and  or JHs design next to the real thing.
It's certainly a filter worth  building and if the discrete designs are
good, or perhaps even, perfect to  human ears, then that makes sourcing
a real 2040 less important for diy  efforts.
************************************** See what's free at http://www.aol.com.
Re: [motm] Re: [AH] Best CEM-3320 circuit : SSM2040/ MOTM 440
2007-06-23 by JH.
>sounds
>440
>the
The original SSM2040 chips are very quiet by themselves, so I guess the
total noise depends on the surrounding circuitry a lot.
>I also notice when the Cat  breaks into resonance at high Q, the
>oscillation is
>breakpoint
>the
>on
>same to
>overdrive.
The 2040 has no internal resonance path, so every designer had to add this
externally, and would do it in different ways. The application in the 2040
data sheet uses a simple potentiometer and a BiFet opamp. Once you want to
get voltage controlled resonance, you have plenty of options to implement
that function (basically a specialized VCA).
The MOTM-440 uses a discrete VCA for this function, with as few transistors
in the signal path as possible.
>the
>bass
>button
This is built upon a special feature of the 2040 (and it's discrete clone's)
topology, which allows rather strong overdrive without too unpleasant
distortion - thus adding the bass frequencies can happen inside the input /
feedback section, rather than after the filter.
>wonder if
The SSM2040 was a very versatile filter building block, that allows for many
different applications. LPF, HPF, BPF, Phaser, you name it. There have been
a lot of publications in Electronotes and elsewhere when this chip was
popular. (And I bet it was popular as long as it has been _available_!)
The MOTM-440 is a complete filter, not a mere copy of a filter _chip_. It's
the equivalent of a SSM2040 _plus_ and all the surrounding components in a
certain (low pass filter) application. So you can't use a MOTM-440 in other
modes. But it'd possible to build all the other SSM2040 applications with
the same discrete technique as the MOTM-440. Hey, I even think you could
modify an existing MOTM-440 to perform HPF or Phasing tasks, but these would
be quite involved modifications.
JH.
