FS: MOTM-110, MOTM-700
2007-04-21 by Mark
After a few people expressed interest, then backed out, I've decided to repost these at lower prices. Since the kits are no longer available, I based my prices on those for assembled and tested modules. Which is what these are. Both units are in excellent cosmetic, electronic, and mechanical condition. MOTM-110 VCA/Ring Modulator $280 This discontinued module, is no longer available from Synthesis Technology. It has two independent sections. The dedicated VCA section has a unique reversible gain control. The other balanced modulator section, with AC/DC coupling switches and level knobs for both inputs, can be used as a ring modulator when both switches are set to AC, as a second audio VCA with one switch set to DC and the other AC, and as a VCA to control modulation depth with both switches set to DC. While it has several different features that are unavailable on the smaller MOTM-190, I'm selling mine because I'm tight on space, and have other signal multiplying gear. http://www.synthtech.com/motm110.html MOTM-700 Dual Voltage-Controlled Router $220 Soon to be discontinued, some consider this to be an extremely useful and unique module. Extremely well-designed, each independent section works with either audio or critical DC voltages, is bidirectional, and can even switch at audio rates. With its four LED's, it's also fun to watch. http://www.synthtech.com/motm700.html Terms: Prices negotiable in U.S. dollars. Pre-pay or Paypal. Buyer pays shipping.
