FW: Imitative Synthesis and Implications for Hardware
2007-04-20 by Adam Schabtach
[ Roger sent this reply directly to me, but intended that it go to the list. --AS ]
-----Original Message----- From: rogerpellegrini [mailto:rogerpellegrini@...] Sent: Thursday, April 19, 2007 6:08 PM To: schabtach Subject: Re: Imitative Synthesis and Implications for Hardware --- In motm@yahoogroups.com, "schabtach" <lists@...> wrote: > > > > So, why is it that (performance) synthesizers have traditionally > > only had one measly filter? > > Because it isn't needed for the vast majority of applications of > (performance) synthesizers--applications which are not imitative > synthesis. Well, the conclusion I drew from my experiment really wasn't "we need serious EQ for imitative synthesis", it was more like "serious EQ is very useful for making interesting sounds - imitative or otherwise". It is my opinion that if one were to walk up to a Minimoog, a Nord Lead or even a modular patched in a traditional VCO-VCF-VCA chain, one would hear a very similar sound. Each of these synthesizers is using subtractive synthesis in a similar and frankly rather crude way - with just one filter. A synth with a powerful EQ would be able to sound quite different and interesting. Clearly, EQ's are used everywhere, to process any recorded sound. It's a travesty that the instrument which should sport the most sophisticated EQ has none. I propose that an interesting (digital) MOTM module would contain, say, 8 adjustable filter frequencies with a serious amount of gain or cut, perhaps adjustable Q, and have the ability to parallel shift the filter frequencies under 1v/octave control. Settings could be stored and recalled.
