motm-120 output
motm-120 output
2006-12-26 by Jonathan Snipes
Hey, just a quick question ... my 120 seems to have a very low output
compared to the rest of my synth ... my oscillators are from dotcom,
and the difference in volume between a raw waveform out of the
oscillator &  the output of the 120 (with all the suboctaves turned
all the way off, and the A IN knob turned all the way up) is
significant ... I also installed the Tellun daughterboard, and the
individual suboctave outputs seem to be of normal volume.
Just curious if this is true for others, or if I assembled mine
poorly (entirely possible)
-Jonathan
Re: [motm] motm-120 output
2006-12-26 by Richard Brewster
What you describe is normal.  The signal from A and B IN through the
mixer with the input switch on NORMAL is *one third of the input level*,
by design.  The level of the outputs from the Tellun daughterboard are
fixed and independent of the input levels.
Richard Brewster
http://www.pugix.com
> -Jonathan
2006-12-27 by Jonathan Snipes
Thanks, Richard - that makes sense.
-jonathan
Richard Brewster
> -Jonathan
