MOTM-650 jack washers
2006-10-22 by Richard Brewster
As Paul mentioned in his update, these are larger than the Switchcraft washers used on other MOTM modules. The jacks are larger in diameter, too, and take a different nut size. A slightly smaller washer, ideally the same outer diameter as the regular washers with an inner diameter big enough to fit the jacks, would improve the appearance of the 650. The washer sizes are: Switchcraft: O.D. 5/8 inch (about 16mm), I.D. 3/8 inch (about 9.5 mm) 650 washer: O.D. 18mm, I.D. 12 mm The ideal washer would be O.D. 16 mm and I.D. 10 - 12 mm (12 is larger than necessary). I am not sure what's the minimum to fit the jack, but it's larger than 3/8 inch. Paul, what hole size is drilled for these jacks? If anyone finds such a washer obtainable in the U.S. in 100 quantity I would be interested. (I imagine that Paul applied due diligence here, but who knows what we all might find.) Richard Brewster http://www.pugix.com
