Synth cookbook?
Synth cookbook?
2006-10-23 by Alpha Ranger
http://www.synthesizer-cookbook.com/id5.html has anybody checked this out yet? comments?  worth buying? nurb
Re: [motm] Synth cookbook?
2006-10-23 by Scott Juskiw
><http://www.synthesizer-cookbook.com/id5.html>http://www.synthesizer-cookbook.com/id5.html
This cookbook is very much oriented towards the beginning synthesist.
The patches are all very simple and use a standard template: 2 VCO, 1
LFO, 1 LPF (either 4 pole or 2 pole), 1 VCA, and 2 EGs (for LFP and
VCA). You don't need a modular synth to recreate any of these
patches, you can do them all on a Pro-One or MS-20. Using a standard
template to work with any synth would normally be quite problematic,
but the author has thoughtfully included a calibration section (and
included an audio CD) so you can figure out which knob setting
responds to 1.4 kHz on your filter (for example). Someone with a
modest modular synth would likely go much beyond the simplicity of
these patches.
So is it worth buying? Depends on who you are.
Collector of all things synth: yes.
Beginning synthesist: yes.
Intermediate synthesist: maybe.
Advanced synthesist: no.
Re: Synth cookbook?
2006-10-23 by Koos Fockens
A better read for the more 'advanced' synthesists (Which I asume most MOTM users are,
afterall it is not often that an absolute beginner stubles across an MOTM system as the
first synth.....) is the following: http://www.cim.mcgill.ca/~clark/nordmodularbook/
nm_book_toc.html
Eventhough it is based on the Clavia Nord Modular, the principles and theory in this book
go much deeper and broader than the above cookbook.
Koos
> these patches.
