It's 650 time!
2006-05-09 by Greg Amann
Hello oot there all you MOTM fans: I currently have Power One +/- 15V supplies running my MOTM stuff. Hopefully, in aboot an hour, the courier from Digi-Key will deliver a Power One +5V supply for me to install into one of my MOTM cabinets. (This estimate was slightly pessimistic. The courier just dropped it off as I type. ;-) ) I will bolt the +5V power supply chassis to earth ground as I did with the +/-15V supply. Do I also need to tie the +5V secondary ground (digital ground) to the +/-15V secondary ground (analog ground) or is this already handled by bolting the two chassis together? (I have NO idea what the plural of chassis is..... chassiseseses?) PLL, BFG
