Weller soldering tips for soldering MOTM Modules?
2006-05-04 by lfosynth2000
Hi!
Id really appreciate some help regarding which soldering tips I should
use for Soldering the MOTM kits.
Im buying a second hand WELLER WECP-S 50W and I want to order some new
tips.
The following tips seems to be avalilable:
-The WELLER "Longlife" soldering tips are available in
the temperatures 260°C, 310°C, 370°C, 400°C and 480°C.
Please help me choose the right temp. tip.
Regards Azzer
Re: [motm] Weller soldering tips for soldering MOTM Modules?
2006-05-04 by Geoff
I use a 370 degree C tip (700 F), and it works great for me, on my
WTCPT.  I'd suggest that one for you.
-Geoff
lfosynth2000 wrote:
>Hi!
>tips.
>Regards Azzer
>Yahoo! Groups Links
Re: Weller soldering tips for soldering MOTM Modules?
2006-05-04 by Koos Fockens
Go for the 370 degree C one.
That's the Mil spec temperature, in other words, the temperature that military electornics
engineers use for a very reliable solder connection. Too high a temp and the flux will
evaporate and the solder not flow out well  enough, to low a temp and it takes longer for
the solder to melt, the danger here is due to the longer heat transfer, more heat goes into
your delicate electronic parts, with higher risk of damage.
--- In motm@yahoogroups.com, "lfosynth2000" <lfosynth2000@...> wrote:
> Hi!
> tips.
> Regards Azzer
