Fw: Fw: [motm] Re: cabinets.
2006-04-15 by Gert Jalass
And the gap is approx. 9mm, i.e. it does work for Stooge rails plus front
panel.
Just be aware that shipment of such a cabinet is not that cheap - I did pay
250 bucks (to Switzerland) for a garage and a top cab ( BAX Global as US
Postal doesn't allow that size ).
Best
Gert
To: "edibennardo" <endiendi@...>
Cc: <motm@yahoogroups.com>
Sent: Saturday, April 15, 2006 5:39 PM
Subject: Re: Fw: [motm] Re: cabinets.
> There is no problem with thickness.  Yes, it provides 26U plus a little
> gap that is handled with Stooge end caps.  I believe all the rails and
> screws are -- or will be -- available from Stooge Industries.
> http://www.stoogeindustries.com/
> Richard Brewster
> http://www.pugix.com
> edibennardo wrote:
>>I see, but if rails must be added and not replaced, i guess rails
>>have their own thickness so the modules would probably protrude a
>>bit outward of the case if I'm not mistaking, unless there's a deep
>>gap in those cabinets between the edge of the cabinet and the
>>internal surface where the modules are attached. I can not tell
>>anything from the pics.
>>What about the number of U spaces? i calculated that a 22 .com is
>>equivalent to 26 motm U plus some gap, is this correct? I'm not
>>familiar at all with inches in this metric latin world :-)
>>Enrico (Italy)
