'650 bug list for V1.0
2006-03-30 by Paul Schreiber
Here are the *known* bugs fir the Version 1.0 firmware: www.synthtech.com/m650/bugs_v1.0.pdf The Sustain (damper) pedal code needs some work, and *some* of the microtuning tables are getting corrupted (but NOT the 12-tone equal tempered or the volts/Hz tables, they are 'write protected' so to speak). I verified the Updater talks to the module (remember, you need *2* MIDI cables to update) and flashes in new code when asked (this is *pretty dang slick*). I'm pooped (it's 1:30AM), I just built up 6 '650s, calibrated and tested all the functions. I averaged 52min per module. Paul S.
