RE: Waveform mixing
RE: Waveform mixing
1999-11-29 by Dave Bradley
> From: JWBarlow@...
> I thought this may in fact be useful (with one big caveat) for
> subtracting
> out harmonics in complex waves (like subtracting out a triangle from a
> sawtooth wave), BUT (the caveat) one would have to add the
> fundamental since
> that would be subtracted out entirely. I'm wondering if anyone has tried
> this, or sees it as being useful? I have tried some initial
> experiments with
> this, and have found that using (from one VCO) a SINE and
> inverted TRI (or
> SQUARE) and an in phase SQUARE (or SAW), sounds better to me than
> using the
> in phase TRI (or SQUARE). I really like the sound and wonder what others
> think.
> JB
I like to do this also. You can cancel part or all of certain harmonics by
varing the amount of the out-of-phase signal that you mix in. You can always
mix the sine back in (non-inverted) to restore some fundamental.
Dave
Re: RE: Waveform mixing
1999-11-30 by JWBarlow@xxx.xxx
In a message dated 11/29/99 10:37:18 AM, daveb@... writes:
>by
As always, Bradley is right!
I've been playing with this technique a bit more since yesterday and looking
at it on the scope (if only to convince myself that I did have the waves in
phase as described -- very interesting to look at!). I still really like it
and think others should look into it. Unfortunately, the VCOs for which I
want to use this technique with don't have a SINE wave.
And do stick it in the Korg since 13V is way more than needed for any (?)
gate signal for any synths -- typically 5V or 10V.
JB
1999-12-01 by Hugo Haesaert
Hi All !
Regarding high gate voltages, i've found my Roland System 100 (not
100M ) needing something like 12.5 to 13 volts as well .  Lower gates
produce incomplete envelopes .
Bye for now .
Keep 'em oscillating :)
Hugo
