FW: [motm] S&H talk
FW: [motm] S&H talk
2006-01-03 by Tkacs, Ken
I agree that the internal clock is an easy candidate for cutting if more panel space is needed. Most modulars end up with a dozen or more LFOs anyway, and if you look at this module as something that you might want to own several of, daisy-chained, then the clocks on the downstream modules become wasted.
“Modularize the module.”
KT
I wouldn't mind losing the internal clock either.
Re: [motm] S&H talk--clock please!
2006-01-03 by Aaron Day
Hi all.
my .02€
Perhaps I am alone on this but I don't have any clocks to spare on my unit and would love to have an accurate pulse (besides using a VCO) to drive my analog sequencers.
If it really isn't needed by the community perhaps the option could be included on the PCB but not on the panel? I could fire up my cheap-o drill press and "mod" the panel to accommodate a jack (somewhere).
best,
ad
Receive-Transmit
Marienburgerstr. 33
VH EG Rechts
10405 Berlin
Germany
www.receive-transmit.com
KT
YAHOO! GROUPS LINKS
2006-01-03 by john mahoney
You should consider adding LFOs to your system, like the MOTM-390:
http://www.synthtech.com/motm390.html
> ... and would love to have an accurate pulse (besides using a VCO) to
VCOs (VC LFOs, if you prefer) are the best for driving sequencers because
they allow you to do voltage-controlled tempo changes. Hey, look, the
MOTM-390 has a VC LFO! ;-)
john
Re: FW: [motm] S&H talk
2006-01-03 by strohs56k
To clarify my idea, I do *not* think the internal clock should be
completely eliminated from the S&H module. (It is valuable and,
because this module is presumably microprocessor based, the internal
clock is "just" software running on the CPU.) What I *do* think is
that a jack to control the asr/loop mode is more valuable than a jack
for CV control of the internal clock. If you want to do the latter,
an external LFO (as a clock source) is the easy solution.
seth
Re: External clock module
2006-01-03 by elle_webb
> "Modularize the module."
It might be interesting to have a more powerful Master clock module
that could be used to drive S&H's or other modules.
It would be nice to have a clock that could output a variety of
subdivisions, like 1/2, 1/3, 1/4, 1/5, etc, via individual jacks.
You'd have a rate knob, and then outputs with clocks at various
subdivisions.
That way doing things like running a couple of S&H's with 3 pulses
against 4, in sync, would be a piece of cake.
For rhythmic music, having a powerful clock controller seems like it
would be more useful than having multiple less powerful internal clocks.
RE: [motm] Re: External clock module
2006-01-04 by John Loffink
Sounds like the VC Pulse Divider to me.
John Loffink
> -----Original Message-----
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
> elle_webb
> subdivisions.
2006-01-04 by djthomaswhite
Hey all, firstly, overall great discussion! The list has been super
active and I have learned a lot from what has been said!
The 730 Pulse Divider will offer us all of the subdivisions and even
more by the sound of it. I would like to vote "for" the inclusion of
a "clock" on the module with an output jack. This would save me from
an LFO and the S&H effects would be in sync with my master clock as
it would be located on the same module. Just my thought on the issue,
Thomas
www.naturalrhythmmusic.com/gear.html
if more
LFOs
might want
downstream
> subdivisions.
it
clocks.
Re: [motm] Re: External clock module
2006-01-04 by Neil Bradley
Or multipliers. I suspect most avoid this because it's "too hard" to do.
-->Neil
Neil Bradley "If you owe the bank $100, it's your problem. If you
Synthcom Systems, Inc. owe them $100mil, it's the bank's problem." - JP Getty
2006-01-04 by Paul Haneberg
Binary Division = Really Easy - A series of divide by 2s - flip flops or
other similar circuit
Integer Division = Not quite as easy - Count pulses then turn on or off -
Easy to implement
Binary Multiplication = Not really easy, but doable - Multiply triangle
waves with precision rectifiers then convert to square waves
Integer Multiplication = Not impossible, but pretty stinkin hard - Only way
I can think of to do this aside from syncable VCOs is to use multiplication
scheme above and then divide using counters - this would still be an
approximation. i.e. 10 stages of multiplication divided by 341 would =
3.003x not 3.000x
Paul H.
Cc: <motm@yahoogroups.com>
Sent: Tuesday, January 03, 2006 8:28 PM
Subject: Re: [motm] Re: External clock module
> -->Neil
> you
> Getty
2006-01-04 by mate_stubb
The Miniwave does clock multiplication. Bank 7 of the standard ROM
does binary rate multiplication from x2 up to x15. The only drawback
is that there is only one output.
Moe
http://www.hotrodmotm.com
http://www.wiseguysynth.com
Still an approximation.
The miniwave's A to D generating a counter from a sawtooth wave addressing a
ROM is effectively the same as a 256x multiplier followed by a divider. But
since you cannot divide 256 equally by three the best you can do is
approximate. You would have two waves at 85 counts each followed by one at
86 counts. So the average is correct, but the timing of the clocks would
vary.
Two thirds of the time the pulses would be .13% short and one third of the
time the pulse would be .26% long.
I don't think you can do a perfect 3x multiplication, but the greater number
of binary multiplications followed by a counter/divider, the closer you
would get. The same thing using a wavetable. The greater the number of
samples per wave the closer to 3x you would get.
BTW if you think about it the 3x approximation would be equivalent to
applying a pulse wave with 33.3% duty cycle to the linear FM input on a VCO
tuned to 3x the fundamental. There would be sidebands generated. Whereas
using a 256x multiplier followed by a /85 divider would get you a proper
square wave, but with a frequency error of 1.2%.
Paul H.
To: <motm@yahoogroups.com>
Sent: Tuesday, January 03, 2006 9:58 PM
Subject: [motm] Re: External clock module
> Moe
2006-01-04 by Mike Marsh
I would like a clock on the module...
> Thomas
> if more
> LFOs
> might want
> downstream
> > subdivisions.
> it
> clocks.
Re: External clock module (humor)
2006-01-04 by strohs56k
If there is a dedicated MOTM clock module someday I think it should
have a BNC on the front panel for 10 MHz reference in. This way we
can sync to a rubidium reference for ultra accurate timing! ;)
2006-01-04 by Larry T.
Couldn't you use Phase Locked Loops to do either/both
divisions/multiplications and even stay totally in the analog domain?
Larry T.
> -->Neil
problem. If you
- JP Getty
2006-01-04 by Charles Osthelder
My synth has BNC I/O...how hard can it be to find rubidium?
2006-01-04 by Aaron Day
I second this. IMO a great idea.
As much fun as it is to drive my MOTM and ACS sequencers from Live
via MIDI I'm longing for "stand-alone" usage of my modular and tape
machines.
i.e. printing a clock (or 2) to my 1" 8 track and then using that to
sequence/compose directly to tape.
I know its old fashioned but... its fun.
>> if more
>> want
> subdivisions.
> clocks.
Re: [motm] Re: External clock module (humor)
2006-01-04 by jfm3
Rubidium won't last as long as a MOTM pot immersed in sea water.
Hydrogen masers are the way to go.
2006-01-04 by john mahoney
I was thinking "cesium."
john
To: "strohs56k" <strohs@...>
Sent: Wednesday, January 04, 2006 12:54 PM
Subject: Re: [motm] Re: External clock module (humor)
2006-01-04 by jfm3
What are you nuts? These things are expensive enough as it is.
> From: "jfm3" <jfm3@...>
